In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
heated shop floor
dan4545 | Posted in General Discussion on October 1, 2007 06:05am
Hey there,
First time I post here, I walked over from the “knots” forum.
Has anyone tried to put in a heated shop floor that can handle rolling around mobile bases (loaded of course).  Here in Quebec, heating the space is not open to discussion, gotta do it.  I use a 220V space heater and it works fine, but I always have that “what if a spark lights the dust …..” in the back of my head.  I keep the space as clean as possible, but…
The only way I’ve seen to heat a floor is by embedding the heating wire in cement and then laying the floor over top.  I might be reaching here, but I’m trying to achieve the most comfort possible.  If I put 2×3 sleepers 16 O.C. (laid flat and screwed to concrete), rigid foam in between, 3/4  ply over top, 1/4″ cement board, then the heating wire (embedded), then some wood flooring, (here’s the question) Is there a risk of damaging the wire when rolling around heavy tools?
Thanks for any replies to this
Dan
  1. FastEddie | Oct 01, 2007 06:31pm | #1
    Soem wood floor manufacturers state that radiant heat cannot be used under their product.  And I would think that if the floor flexes with the rolling loads, you are at risk of damaging the wires.
    rjw | Oct 01, 2007 06:41pm | #2
    Consider using hot (warm) water circulating through pex embedded in concrete. A standard water heater might be usable, depending on the BTU requirements.
    The electric panel systems I have seen for radient floors are very expensive and intended primarily, I believe, for "small" bathrooms and the like.
    May your whole life become a response to the truth that you've always been loved, you are loved and you always will be loved" Rob Bell, Nooma, "Bullhorn"
    "We Live" http://www.youtube.com/watch?v=7kuBgh0VCqI&mode=related&search
    And Annie Ross's "Twisted" http://www.youtube.com/watch?v=8lqivrCIRGo&mode=related&search=
    Edited 10/1/2007 11:42 am ET by rjw
  3. DougU | Oct 02, 2007 05:01am | #3
    Our shop and the one that we  moved out of have/had radiant heat floor, hot water through pex. Works well and we don't have any space heaters.
    Our winters are not nearly as cold as yours but they aren't all that balmy either!
    Edited 10/1/2007 10:01 pm ET by DougU
    1. dan4545 | Oct 02, 2007 12:55pm | #7
      Hey Doug
      What type of flooring do you have in your shop?  I've thought of hardwood, laminate, or just plywood.  I think the negatives for each would be (in the same order) big gaps in winter, thin (weak as a workfloor), and soft (won't last).
      1. DougU | Oct 02, 2007 02:08pm | #8
        Dan
        We have a poured concrete floor. Wood would be nice for the feat but I'm not sure how practical that is for a shop thats 10-15,000 sq ft.
        I'd rather be standing on anything but concrete all day long but nobody asked me! We do have mats around the shop and that really helps.
        I'm no expert, hell I'm not even a novice when it comes to in floor heat but I've been around this shop and our other one and on days that are -20° outside our shop is just as warm as you'd want it to be.
        Ours is run by a boiler, thats about all I know about it. I can get more info if you'd like.
        1. dan4545 | Oct 02, 2007 02:20pm | #9
          I'm not too concerned about the water heating thing, and I think I have a solution to my flooring question, I'll just install a wood floor as a floating floor.  That should take care of the gaps.  I'm not worried about the edges where the floor will meet the wall, there can be a sizable gap.
          Thanks to all for the replies
  4. billybatts | Oct 02, 2007 05:06am | #4
    there is a electric radiant heat manufacturer based out of Qc. Wires supply the heat as opposed to plumbing.
  5. ponytl | Oct 02, 2007 05:13am | #5
    the warm/hot water  system from what i've read will cost you less to keep warm than any other system... because you get to "save/store the heat...
    there are some pretty cheap passive solar systems out there that could save you even more...
    as others have stated even a small standard hot water heater will do the trick
    p
  6. Stuart | Oct 02, 2007 05:42am | #6
    Hydronic in-floor heat is great stuff.  A friend of mine has it in his garage here in Minnesota and it's very comfortable heat.  He uses a regular water heater and a small pump with good results.
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
