Hey Pif – Mike…
IMERC | Posted in General Discussion on July 26, 2009 02:59am
Got a shake shingle roof with about 15/20% curled shingles when dry…. less than 5% when they are wet/damp… edge curl, not tab lift…
the HO wants it repaired/flattened…
I figured to replace the curled shingles but since shakes were outlawed a few years back getting replacements are a tuff call around here…
this roof receives zero shade… and there are no leaks… cold roof type installation.. 5/12… 24″ shake with 5/7″ irregular exposure… nominal 3/4 thick at the tab…
so… what do you suggest???
it’s rained about everyday since what seems the beginning of time there…
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming <!—-><!—-> <!—->
WOW!!! What a Ride!
“Some days it’s just not worth chewing through the restraints”
  1. MikeSmith | Jul 26, 2009 04:22am | #1
    imerc... so these are  shakes with a sawn back ?
    1st problem is getting a source... can you find these shakes .... special order ?
    my inclination would be to  replace sections all the way to the ridge
    on the theory of .. "if you touch it , you own it "
      IMERC | Jul 26, 2009 04:32am | #2
      not sawn on the back....
      the owning deal crossed my mind....
      finding a source isn't as easy as i originally thought...
      replacing to the ridge... might as well tear off and reroof the whole deal...
      WOW!!! What a Ride!
      1. MikeSmith | Jul 26, 2009 04:47am | #3
        so , real shakes...
        typical install is course.... then 18" strip of roofing felt...
        then course.... 18" strip of roofing felt
        so the felt is part of the waterproof... and it's almost impossible to thief a shake out... then slide a new shake in without bunching up the felt and destroying the  waterproof....
        if it were a minor replacement  maybe... perhaps he'd like you to belt sand the curl ?
        maybe paul or seeyou or walter or someone has a better idea
          IMERC | Jul 26, 2009 05:07am | #4
          that's the detail... the strapping is 2x4's...
          sanding or planing is out...
          thought of face nailing the curls with SS ring shanks since the shingles are soaked and somewhat pliable...
          other than the curls.. the roof is in good very shape...
          BTW... they're 24's and not 18's...
          attempted a theifing.. they're nailed with at least #10HD galvs...
          WOW!!! What a Ride!
          1. MikeSmith | Jul 26, 2009 05:16am | #5
            be interested in other viewpoints.. but it seems to me... strip a vee to the ridge  or  let someone else buy the headacheMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            Sphere | Jul 26, 2009 02:59pm | #11
            I dunno, sounds like the installer ( notice I didn't say roofer) didn't cull the flatsawn ones that show up in a bundle. That and didn't split the holy mother wide ones or set em aside for hips valleys or ridges.
            Last Shake job I did was 24" at 7.5 and I had ridge caps to premake ( woven) and all wides got set aside to be ripped, or a hatchett whack to keep em reasonable, but I doubt I had many over 8" wide any way, and under 8" when properly split ( Vert. Grain) they don't misbehave.
            Last month I did a 14 sq. cedar shingle roof and had a LOT of sapwood and deadwood ( too brittle, real dark brown) and few flatsawns..they got culled.  Roof came out great.
            I wonder why if its so sopping wet, and the shakes are pliable, they didn't face swell and cup the other way if the backs are still dry?  And for a 3/4" butt to cup / curl they HAVE to be flatsawn..I'd chase the installer, supplier.
          3. MisterT | Jul 26, 2009 02:47pm | #9
            Marty, sneak a hack saw blade up under to cut the nails.then flip over the curled shake and re-insert.or tell the guy that if he wants flat roofing you will price out a rubber membrane...or concrete (brownbagg could do it).
            "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
            If Pasta and Antipasta meet is it the end of the Universe???
            according to statistical analysis, "for some time now, bears apparently have been going to the bathroom in the woods."
          4. Piffin | Jul 26, 2009 03:04pm | #14
            "tell the guy that if he wants flat roofing you will price out a....."Yeah, Shakes are supposed to look rough!I suspect the installer did not "read the grain" which he hailed them. the 10d nails suggest inexperienced overkillers doing the work, but it ain't leaking, so I ain't touching it. Can't afford to own it.
          5. MisterT | Jul 26, 2009 07:47pm | #28
            "Can't afford to own it."One of the main reasons I no longer do roof jobs,no telling what the previous hacks did to cause a problem.so I tell people my insurance doesn't cover me for roofing..
          6. Piffin | Jul 26, 2009 03:00pm | #12
            face nailing with ring shanks for that many shingles would have a leak caused within 2-3 years more or less depending on the climate
          7. User avater
            IMERC | Jul 26, 2009 04:30pm | #16
            got it...
            WOW!!! What a Ride!
          8. Piffin | Jul 26, 2009 04:37pm | #17
            at 28 years old, it is starting to have some surface erosion. That is why it is acting up. nearly time for a new roof anyways. He can do it now or wait until a few fall off and it is actually leaking in another few years. I definitely wouldn't try 'fixing' it now though. That's like giving a sixty year old woman a boob job
          9. User avater
            IMERC | Jul 26, 2009 04:47pm | #18
            thyanks Pif...
            WOW!!! What a Ride!
          10. Shoemaker1 | Jul 26, 2009 05:53pm | #19
            Shakes Illegal?
          11. Piffin | Jul 26, 2009 05:54pm | #20
            fire danger
          12. User avater
            IMERC | Jul 26, 2009 06:17pm | #22
            he said/she said....
            she say's 36 years since the house was built...
            WOW!!! What a Ride!
          13. Piffin | Jul 26, 2009 06:24pm | #23
            40 years is getting to about a maximum time - life span for that roof
          14. User avater
            IMERC | Jul 26, 2009 06:28pm | #24
            1st time the repair Q was asked I said new roof...
            but the HO wants the shakes...
            so then it became a repair/renew issue...
            will have to wait till tommorrow to get an AHJ verdic....
            WOW!!! What a Ride!
          15. Piffin | Jul 26, 2009 07:00pm | #26
            Do they permit fire treated shakes?This is a strange scenario, since I know there are land covenants in COLO subdivisions and delelopements that require shakes only, but since those were written into the deeds, the state had thiose wildfires and drought that precipitated a lot of 'no wood roof' rules in the codes.
            So a lot of people will be facing this dilema as their existing roofs come due for replacement.
          16. User avater
            IMERC | Jul 26, 2009 07:10pm | #27
            dunno the exact why's how's when's or the can/can not do's... will tomorrow though...
            WOW!!! What a Ride!
          17. User avater
            IMERC | Jul 27, 2009 05:40pm | #29
            no repairs, replace with yur choice of materials as long as it isn't wood...
            WOW!!! What a Ride!
          18. Piffin | Jul 26, 2009 06:47pm | #25
            http://www.millenroofing.com/wood/article_01.htmlgood case study on the subject here.
          19. User avater
            IMERC | Jul 26, 2009 06:16pm | #21
            yup...
            fire danger...
            WOW!!! What a Ride!
  2. MisterT | Jul 26, 2009 05:20am | #6
    Well this one is SOOOOOOOOOOOOOOOOO obvious...
    Piffin screws will hold 'em down.
    use fender warshers on the stubborn ones.
    Do I gotta come up with ALL the good answers???
      IMERC | Jul 26, 2009 06:03am | #7
      I love it...
      you sign off on it and it's a done deal...
      WOW!!! What a Ride!
      1. MisterT | Jul 26, 2009 02:42pm | #8
        The reputation behind the "Piffin Screw" brand should be enough to seal ANY deal....
        1. Piffin | Jul 26, 2009 03:01pm | #13
          The Piffin screws would work if he painted the roof blue afterwards!
  3. Piffin | Jul 26, 2009 02:58pm | #10
    Where are you nowdays?
    how old is this roof?
    Do you know if these were laid like shingles or if the have felt interwoven like shakes should have?
    The symptoms suggest that it was laid without interwoven felt over a tight felt base of maybe even total I&W.
    My thought is that the problem is cosmetic only since it is not leaking and it is a " not broken, don't fix it" situation where trying to replace 20% of the shakes would be likely to cause more problems than it fixes while costing a lot of money - so much that it it is really that ugly to the HO, bid a brand new roof replacement done right.
      IMERC | Jul 26, 2009 04:29pm | #15
      Colorado..
      28 years...
      felt inter-weave...
      WOW!!! What a Ride!
Picture-Perfect Pergola
