At 3:30AM last Wednesday, most folks in my community were awaken to what was probably the loudest and prolonged lightning strikes the wife and I have ever heard of. At 4AM after not being able to get back to sleep, I started looking for damage. By 5AM I had damage to two flat panel HDTV’s, a Sony PS3 Playstation, networking gear (network router, Ethernet switches, etc.)and three personal computers. Everything that sustained permanent damage had a grounded power cord plugged into a surge suppressor (no such thing as a true protector). Surprisingly, some of the devices that were plugged into the same surge suppressors and flat panel HDTV’s were not damaged at all, and even more surprising is that they didn’t have grounded power cords. Additionally, my telephone (AT&T) and cable modem Internet (Comcast) services were out. I called Ma Bell and the whole street was dead. By 9AM more than 12 homes were assessing the damages. All Wednesday and Thursday, AT&T, Comcast, DirecTV, and Jackson EMC had been working on the street making repairs. Some households are still without telephone, cable, satellite services. One home didn’t get full electrical power back until late yesterday. On Wednesday afternoon I was talking to one of the AT&T power crew folks along with a guy from the power company and learned something very startling. Because there isn’t much earth underneath our feet in my neighborhood, the resulting granite makes lightning discharges difficult to dissipate. Listening to these guys talk they said they frequently are dealing with lightning traveling up building ground wires and into structures. Pointing to the lawn torpedoes, cable and telephone boxes on sides of homes, etc. will witness a lot of burned stuff resulting from this particular event. And I am wonder if this has affected my HVAC for my first floor as ever since this event the gas furnace is cutting off way too early in its cycle (set it to 72º and its cutting off at 66). Other appliances like washer, clothes washer and dryer, refrigerator, microwave and electric oven, etc. appear to be fine.
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
here is some hindsight for ya.... When we start getting those kind of lightning strikes we start unplugging stuff like TVs and computers.
BTW - that pic you have there - is that the "go ahead punk - make my day" scene? Or am I a decade or 2 off?
It is Harry and that scene. One of my all time favorite movies.
BTW, that lightning bolt came without notice. It was dead calm before it happened. No rain, no storms, no distant sounds of thunder. Just BAM! :)
I would bet that most of your damage came in on the cable and phone lines, not the power line. You should at least have some sort of surge protector on the incoming cable line (not counting the lousy one the cable company may provide), and on the phone line as well, if it's connected to anything more expensive than a $69 K-Mart phone. It also helps to add a separate ground wire to the cable modem, as generally they aren't grounded through the "wall wart" power supply.
Grounding (to "real" ground) isn't really a requirement for surge protection. Rather, what's needed is to limit the voltage differential between the various wires connected to the equipment. Your better surge protectors include both MOVs to ground and MOVs between hot and neutral, to limit these differentials. But you also need to limit the differential between cable wires and power wires.
Dan,
Reading his story, it sounds to me like the lightning was hitting the ground, and since the granite is so close to the surface, it was running/dissipating TO the grounds on the houses in the vicinity.
Kind of a backwards kick in the pants...
Howinheck does one protect against that sort of backwards surge ?
This is exactly the case as I was told by the electrical coop and telephone power systems guy. I have no idea how I am suppose to protect from that entry point especially when I had no warning that bad weather was coming.
Certainly there are some scenarios you can't protect from, and there are indeed many way for the surge to enter the system.
The shallow granite (which is an insulator, I suspect) combined with relatively dry soil would prevent the ground from equalizing, and a strike in one location could raise the potential of the ground in that area relative to other areas. This would then cause surges to radiate out over phone, cable, and electrical lines coming from that area, in the process toasting equipment in the area connected to those lines (in addition to less severe damage to distant equipment).
But sometimes it's just the massiveness of the strike. A lightning bolt induces voltage/current in any parallel metallic objects nearby, including wires, pipes, metal support posts, etc. This can result in damage even to isolated equipment.
I am wondering why the two flat panel HDTVs were damaged yet the surge suppressors exhibited no damage. Not even their breaker/fuse were compromised. I would have thought this would have been the case considering how many joules they were rated for compared to what the bolt delivered.
Same thing for the three computers, which had their network interface chips on the motherboard damaged. The data network for them runs through Ethernet switches to a router to a cable modem, which runs through a surge suppressor coax interface then outside.
I've found no visible evidence that the surge suppressors were even engaged let alone exhibit a change in their ability. Maybe they are hollow and nothing more than a power strip.
The flat panel HDTV's were
The flat panel HDTV's were connected via satellite equipment and had no telephone or cable connections. The Sony PS3 had no telephone or network connection (used for Blu-ray playback not online gaming). The DirecTV HD DVRs that were NOT damaged were connected to the telephone lines. The three damaged PCs were connected to the home data network via the cable modem, router, and switches, which were also damaged.
BTW, the cable coax runs through the surge suppressors as does the telephone lines plugged into the HD DVRs.
If this particular kind of 'strike' were the 'norm'... then I would suggest a fusible link.
But this is backwards from the norm, and it you put in a fusible link, that will negate the protection it is intended for, in the first place.
Peculiar.
