How strong are rivets in shear….
jerseyjeff | Posted in General Discussion on August 22, 2006 07:30am
I am putting together a small trailer to be towed behind a mtn bike.   I will carry 2 kayaks (about 80 lbs)  and paddles on a cinder rail bed (  out by ohiopyle pa)  I am using 1 inch square aluminum tube that is bent and braced with 1/8″ thick Al  flat stock.   I have secured the braces with 5/16th long 3/16 diameter rivets,  and I am now wondering if I should also through bolt my cross braces.   (I did fillet the braces with JB Weld too….
    IMERC | Aug 22, 2006 07:51am | #1
    pure shear in alumunum...
    bolts are better... use SS..
    WOW!!! What a Ride!
    IMERC | Aug 22, 2006 07:52am | #2
    BTW.. don't build too rigid.. you'll want some flex....
    WOW!!! What a Ride!
    xxPaulCPxx | Aug 22, 2006 10:03am | #3
    My suggestion is you take whatever you thing the actual load might be on any shear connection - say 100 lbs for example - and multiply it by 10.
    In this example the 100 pound load might actually be 1000 at any given point, if you consider bumps WITH acceleration WITH drag.
    Here is how you make a controled 1000 lbs force on a riveted connection.  Get a 20 lbs weight.  Get a metal bar 50 inches long.  Rivet at 1 inch to a stationary piece of metal.  With the end closest to the rivet stabilized on a ledge, hang the 20 lb weight at the other end of the 50 inch long bar.  In this case:
    Applied Force = (Weight x distance from pivot weight is applied) / distance from pivot that force is applied
    so
    1000 = (20 x 50) / 1
    If your rivet shears off there (or wherever you calculate) you may want to reconsider your choice of fasteners.
    This safety ratio for live loads was what I was taught many years ago in building sets.  If you build something to carry a dead weight, built it to carry twice the weight.  If you build it to carry a person, built it to 10 times the person (and whatever they are carrying) weight.  When a person jumps, they can deliver ALOT more force than they apply standing still.
    Also a CRX fanatic!
  4. DanH | Aug 22, 2006 01:12pm | #4
    Well, airplanes are put together with rivets, but the rivets are speced for the job. It all depends on the rivets.
    1. Piffin | Aug 22, 2006 01:48pm | #5
      skyscrapers are tied together with riviets too, but I would not trust any load to an AL rivet. They are OK for gutters to make the joint is about all, IMO
        IMERC | Aug 22, 2006 01:58pm | #6
        not any more....
        proven to fail...
  5. junkhound | Aug 22, 2006 05:23pm | #7
    You need to tell us what the alloy of the Al tubing and brackets are, and what the rivet alloy is.  If you 'bent' the Al tubing, it is likely 6061-0 or T3 at the best, doubtful for use on a trailer that would be subject to fatigue, shock loads, etc.
    As already implied in previous posts, Al rivet specs range from soft to better than mild steel.   If Home Depot or Harbor Freight pop rivets (or very soft Al), drill them out and put in a couple of 1/4" bolts - plated mild steel OK for your low loads.
    A 2x proof load on the entire trailer may be in order like suggested, esp. if soft Al tubing was used.
    1. jerseyjeff | Aug 22, 2006 05:32pm | #8
      Ahhh...  the rivets are spaced so that it will be real easy to leave them in place and through bolt too..   I thought ahead on that one!
A New Approach to Foundations
