how to plug a hole
brucet9 | Posted in Construction Techniques on July 29, 2008 08:47am
I drilled a 7/8″ hole for a deadbolt about 7/16″ too high. Oh well, I thought, I’ll just glue in a piece of 7/8″ dowel and re bore the hole.
You guys probably already know that didn’t work because 7/8″ dowels are about 1/32″ undersized.
So how do I plug my error so ther’ll be some “meat” around the upper screw of the deadbolt strike?
BruceT
    Luka | Jul 29, 2008 08:54am | #1
    Get a piece of 1" dowel and sand on it until it fits the hole snugly.
    Glue it in, and Bob's yer uncle.
    Click here for access to the Woodshed Tavern
  2. TomT226 | Jul 29, 2008 01:24pm | #2
    Square it up with a chisel and rip some out of a 2X to fit...
    McDesign | Jul 29, 2008 02:10pm | #3
    don't put in a dowel - the grain runs the wrong direction and it will always show through paint.
    Make a face-grained piece (of the same-ish wood, likely fir?) to glue in.
    IMERC | Jul 29, 2008 06:30pm | #4
    cut a plug using a hole saw...
    match up the grain....
    WOW!!! What a Ride!
    1. Novy | Jul 29, 2008 07:22pm | #6
       We allways do what IMERC reccomended and set the plug in bodyfiller for paint grade or epoxy for bright finish.
      On a hill by the harbour
  5. TomE | Jul 29, 2008 07:08pm | #5
    I occasionally fabricate longer/wider strike plates and/or larger escutcheons out of matching metal to cover old installs of door hardware when installing new.
    Might be able to do similar in your situation.
    Bright brass is easiest to do.
  6. MikeHennessy | Jul 29, 2008 08:51pm | #7
    Where's Sphere when you need him.
    Oh well, I'll fill in for him this one time.
    HI! BILLY MAYES HERE, FOR SUPER PUTTY! Etc. Etc. Etc.
    Mike Hennessy
    Pittsburgh, PA
  7. brucet9 | Jul 30, 2008 03:01am | #8
    Thanks guys for the suggestions. Now I know some resources for repairing damage to good visible surfaces.
    I ended up using a piece of 7/8" dowel after all. I cut it to length, coated it with wood glue, inserted in the hole, split it with a chisel and hammered a glued shim into the crack to press the halves against the edges of the hole. Not good enough for finished work, but for this, out of sight under a deadbolt strike, it gave me the support I needed for the strike plate and it was solid enough to re-drill the hole for the bolt with a spade bit. I drilled clear through my plug for the upper strike screw and used 2 1/2" screw that could reach through into the trimmer.
    BruceT
    1. reinvent | Jul 30, 2008 06:28am | #9
      Looks good from my house.
Two Ways to Test Windows
  • The New Old Colonial
