Any way to use a say 3000 watt Honda generator to make hot water?
or do the 4500 watt elements act as an overload to the generator (or would you just get hot water slower?
I'd just use fire.
its hot enough during hurricane seasn that we just shut the hot water heater off .
you gotta let the shower water run a while to get cool enough to shower .
hot water would be my last use of power
I made this copper coil that I lay in the gas grill. hook a hose to, and get all the hot water needed.
You could run the WH on 120V, or replace one of the elements in the WH with a lower wattage one. But hook a 3KW genset to a 4.5KW element and (hopefully) the genset will immediately go offline or blow a fuse.
