HVAC Question – Humidity
gmcdave | Posted in Energy, Heating & Insulation on February 5, 2008 07:40am
Hello: I am restoring a 1920s bungalow in the Seattle area. It has a full basement and is heated with an oil furnace. I am trying to understand the physics and psychrometrics of what’s going on in the house. Consider a typical winter day with outdoor conditions at 39F and 88% RH. If I take this air and heat it Sensibly (horizontal process on the psychrometric chart) to 70F, shouldn’t the RH in my house be about 28%? But it is typically about 60%. What is happening here? Is this normal?
Dave
  1. DanH | Feb 05, 2008 07:51pm | #1
    Probably normal for Seattle.
    You've got moisture coming from somewhere. If you're lucky it's just showers, cooking, and soil moisture coming through the foundation. Or it could be a leaky roof, rotting walls, etc.
  2. Riversong | Feb 06, 2008 09:56pm | #2
    One of two things:
    1. there's insufficient air exchange to ventilate indoor humidity (unlikely in a 1920 bungalow)
    2. there's too much humidity being introduced into the house, either from occupancy use or from basement or other environmental source (likely in a 1920 bungalow with full basement)
    Solution: find moisture sources and seal them and vent occupancy moisture at its source (bath fans, kitchen hood, external drier vent).
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
    1. gmcdave | Feb 06, 2008 10:33pm | #3
      Thank you. So if I did all those things faithfully, (and assuming I'm not getting a tremendous amount of moisture from my basement), could I expect the HR to be in the 28% range (sensible heating from 39F, 88%RH to 70F)?
      Dave
      1. Riversong | Feb 06, 2008 11:48pm | #4
        That's about right.
        Which is why leaky houses (especially wood-heated houses because of the make-up air drawn into the envelope, heat stratification, and stack effect) are dry in the winter and why tight houses are too humid absent effective ventilation.
        Design *  * Build *  * Renovate *  * ConsultSolar & Super-Insulated Healthy Homes
        Edited 2/6/2008 3:50 pm ET by Riversong
A Practical Perfect Wall
  • The New Old Colonial
