We would like some ideas on constructing stressed skin panels which will be bolted to steel web joists and covered by shingles.
We have massive amounts of extruded polystyrene insulation (xps) and need to know what type of adhesive might be used to sandwich this material between 4×8 sheets of OSB.The panels need to be 6 inches thick so we will be using 3 layers of 2 inch xps between the osb.
Thanks;
Don Lauer
DLauer [email protected]
Don
Hopefully these people should be able to lend you some advice.
http://www.gougeon.com/
I have a high regard for their products I've used on a boat or two.
Scott
Scott;
Thanks for the web site.My first thoughts on a two part adhesive are that they will be over-kill.But will contact Gougeon Bros. for technical advice.Thanks for your response.
Don L.
We have massive amounts of extruded polystyrene insulation (xps) and need to know what type of adhesive might be used to sandwich this material between 4x8 sheets of OSB.The panels need to be 6 inches thick so we will be using 3 layers of 2 inch xps between the osb.
Thanks;
Don Lauer
