Morning All,
Many of you might have heard of in-wall speakers where the speaker is built into the wall, but has anyone heard of or can reference in-wall lighting?
Unfortunately the words in+wall used in search strings is treated grammatically and not literally.
Recessed lighting is the term used for ceilings. Maybe it will get you to wall lighting too? buic
Try "recessed wall fixtures." in your search.
what are you trying to accomplish.
The only true in wall lighting that I know is the small units that are used by steps and in hallways to light the path.
And the only true light walls would be frost glass or other translucent material with back lighting. Might be used for dramtic affects in a night club.
You mean your walls don't just change from an opaque, painted drywall surface to a glowing, translucent surface at the push of a button! Must be an old house!
Well based on what you said about your "mentor" I got a great idear.I just knocked out one wall of the house.And now it changes color from black to green or white depending on the season..
You can find in-wall lighting inside the spray booth at your local auto painting shop. Only place I can think of where it would be useful.
http://illusion.manufacturer.globalsources.com/si/6008825673216/pdtl/Solar-ground/1006794825/Under-Inground-Floor-Recessed-LED-Light.htm
http://www.globalsources.com/manufacturers/Wall-Sconce-Light.html
Wall sconce, LED, indoor and out
I wonder if they allow business with consumers directly, or are forced to go through a distributor and retailer.
