Installing a stove
yojimbo2 | Posted in General Discussion on December 7, 2007 07:04am
I have started using “Magic Sliders” when installing stoves in my kitchen remodels.  I installed a heavy duty six burner model today on a newly tiled floor.  It had metal feet.
The Installation package came with 1/8″ masonite runners and a board that you were supposed to place on the floor so as to protect it.  They also recommend using a furniture dolly to move the stove around.
Here is what i did.  I set the runners and the board aside.  I removed the overn door, racks etc.  I layed the stove on its back, placing cardboard between the stove and the floor.  I placed the magic sliders on the bottom of each leg.  I then got the measurement that I wanted my stove to be in relation to the top of the counter, and adjusted each leg accordingingly.  I tipped the stove up and slid it into place to check the height.  I was able to fine tune the height easily because the magic sliders make moving the stove in and out a breeze.
  1. MikeHennessy | Dec 07, 2007 03:28pm | #1
    Do you leave them in place under the legs when you're done?
    Mike Hennessy
    Pittsburgh, PA
      Heck | Dec 07, 2007 04:57pm | #2
      Weird when you leave the kitchen, and the stove is right behind you...
    2. yojimbo2 | Dec 08, 2007 05:28am | #4
      Yes. Dishwashers are starting to come with leveling kits. Plastic sleds that allow you to adjust the rear legs once the dishwasher is in place. Fantastically easier install.
    JDRHI | Dec 07, 2007 05:16pm | #3
    Not a bad idea.
    J. D. Reynolds
    Home Improvements
  • Smarter Stop Block
  • Square Walls Solo
