Installing foil faced insulation sheets
Crabbstructor | Posted in Energy, Heating & Insulation on February 12, 2007 05:16am
I am looking for the right stuff to install a foil faced sheet insulation to my block walls.  It is on the inside of my home.  I am getting ready to remodel my living room and it is a block wall.  When I did the exterior I used a foam board and they make an adhesive for it, I have yet to see one for the foil backed stuff yet and was wondering what I should use???  Any help would be greatly appreciated.
  1. rez | Feb 15, 2007 12:14am | #1
    Greetings Crabb,
    As a first time poster Welcome to Breaktime.
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    only life affirming platitudes allowed -Doud '07
    Would a full cluster of enemies be called an enema? -Piffin
  2. rez | Feb 23, 2007 02:42am | #2
    Well, let's try this again.
    bump
  3. woody1777 | Feb 23, 2007 03:52am | #3
    The standard PL foam board adhesive should work, shouldn't it ? I dont have a tube handy to check, but I dont remember any specific injunctions against that last time I was around.
    If ya dont have a specific reason for wanting foil face, might be easier to just go with what ya know......
    Just my $.02
    A human being should be able to change a diaper,  plan an invasion,  butcher a hog,  conn a ship,  design a building, write a sonnet,  balance accounts,  build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specializtion is for insects. - robert heinlen
  4. barrmo4321 | Feb 23, 2007 03:59am | #4
    The method that is common around here is to tapcon or conc. nail strapping (wood or metal) at 23" spacing then use the sheet rock to hold the foam on. I guess you could tapcon one screw per foam piece to hold it steady while you carry the sheetrock in. goodluck Barmo
  • Fine Homebuilding's Author Guidelines
