Lattice Panels
MichaelNYC | Posted in General Discussion on May 13, 2008 06:10am
Hi,
I’m planning on making a series of lattice panels to screen parts of my yard. They will likely be 8′ wide by 8′ high. I plan on using 4×4 posts for the sides so that I can sink them into the ground for stability (in concrete).
Does it make sense to make the entire frame out of 4×4, then put in the prefab lattice (two sheets, vertically, with a seam in the middle)? Is that overkill? I am going to make four of these screens. Any advice would be appreciated.
Thanks,
Michael
    xxPaulCPxx | May 13, 2008 07:08pm | #1
    Latice is very very bendy, and wood in concrete can be very very rotty.  A pretty setup today might look like a funhouse in 5 years.
    The latice will need a full frame (all 4 sides) to give it a little structure.  Are you using synthetic or wood latice?
    Also a CRX fanatic!
    If your hair looks funny, it's because God likes to scratch his nuts.  You nut, you.
    bobl | May 13, 2008 07:10pm | #2
    account for expansion/contraction
    account for wind load/movement
    don't want lattice to come apart
    can't tell how you plan to connect things together
    bobl          Volo, non valeo
    Baloney detecter    WFR
    "But when you're a kibbutzer and have no responsibility to decide the facts and apply the law, you can reach any conclusion you want because it doesn't matter." SHG
  3. DanH | May 13, 2008 07:15pm | #3
    I wouldn't try to do 8x8 panels with prefab lattice. Even 4x8 is iffy. Stick in some 2x4 mullions or some such.
    In most parts of the country a 4x4 in concrete is an invitation to rot.
    What is wanted is not the will to believe, but the will to find out, which is the exact opposite. --Bertrand Russell
    1. MichaelNYC | May 13, 2008 08:03pm | #4
      It does seem likely that the 4x4 would rot pretty quickly. Should I be pouring footings and attaching the posts with anchors like a deck footing?I was going to use the pre-fab lattice to save some time. Any other ideas would be welcome.Thanks.
      1. DanH | May 13, 2008 09:25pm | #5
        In some soil conditions the best choice is to backfill with crushed rock. Using post anchors isn't really practical for a fence.
        xxPaulCPxx | May 13, 2008 10:26pm | #6
        Instead of concrete. you could use the metal posts bases that you hammer into the ground and attach 4x4 to the top of.  They are about $15 IIRC.  You can make them prettier at the top by covering them with wood attached to the 4x4.
        Here is a pic of my use of lattice for a Jewish holiday structure called a Sukkah.  It's only up for about 10 days a year, so I hang the synthetic latice on the sides with zip ties.  The overhead redwood lattice has a frame of 1x1 redwood for support and durability.
        View ImageRebuilding my home in Cypress, CA
        Also a CRX fanatic!
        1. Piffin | May 14, 2008 12:10am | #7
          Those metal bases driven in the ground are designed for mailbox posts. They would not begin to stand up to any wind with that much lattice surface.
            xxPaulCPxx | May 14, 2008 01:19am | #9
            Well, they did well when I used them on my fences back in Illinois - including the ones that were big pre-fab ceder panels (6'x8' IIRC).  The long ones go 36" into the ground.Rebuilding my home in Cypress, CA
            Also a CRX fanatic!
  4. Piffin | May 14, 2008 12:15am | #8
    I don't know about where you are, but we can get lattice in about five different materials and qualities premade.
    But for an 8x8, you will still have trouble getting things to line up neatly at the joint. Just for appearance, I prefer to make my own using strips nailed to a frame with dabs of glue also.
    For posts, use cedar or PT ground contact, and put some stone at the bottom of the hole for water to drain into down there, then compact the soil tight around the post.
    Run a 2x4 top and bottom rail with a 1x2 nailer for the lattice on those and on the posts - a 2x4 at the center seam if you use premade.
    Ted W. | May 14, 2008 03:44am | #10
    Posts in concrete shouldn't pose a problem with rot as long as the top of the crete is above ground. It's ground contact, with the constant moisture, that causes rot. Also, use good quality treated lumber, such as Wolmanized. The cheap junk they sell at most big box stores will shrink, twist, crack and rot a whole lot faster.
    I know someone here will surely correct me about using Wolmanized, saying you should use #60 (?) for ground contact. They will have my attention too, as I'm just a little ignorant on that issue.
    Make sure to get good quality lattice as well. The cheaper stuff is thinner and not treated as well. Better qualiyt lattice uses 1/2" thick strips while some of the cheaper stuff uses 3/8" or thinner. Better stuff is also more thorougly treated and will be green in appearance.
    Cheap Tools at MyToolbox.net
    See some of my work at AWorkOfWood.com
Sloping a Deck: Is This Necessary?
Mike Guertin explains which areas of a deck you need to pay attention to in order to deal with drainage.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
