Leveling sleepers for T/G pine floor
waynew | Posted in Construction Techniques on April 2, 2007 07:15am
Hi,
This is my first time installing a wooden 1 1/2″ thick T/G floor pine floor, its for the workshop in a double garage. Just wanted to run my final plan via some of you with more experience than I.
I’m located in Ontario Canada, so it gets cold. Firstly I’m putting down a 6mm moisture barrier then a frame around the room using 8″ sleepers ripped to level out the slope in the existing concrete floor. Then lay sleepers at 16″ centres between the frame which will again be ripped to level out the slope of the concrete. I’ll place shims every 12″ where the sleepers dont meet with the concrete and use string line with level to get a level surface as the sleepers are being layed.
Apparently blocking is not necessary but can help during the construction process so I plan on putting it down when necessary.
Is it absolutely necessary to tapcon the sleeper to the concrete? There will be some fairly heavy equipment placed on the floor when complete.
Will the shims stay in place by themselves or do they need to be glued to the bottom of the sleepers.
Anything else?
Thanks,
Wayne
Edited 4/7/2007 4:55 pm ET by waynew
    waynew | Apr 03, 2007 03:45am | #1
    Another question that just came to mind: Would it be better to leave a small gap between the sleepers and concrete along the whole length for shiming or get as close a fit as possible to the concrete resting directly on the concrete as much as possible.
    Regards.
    1. ponytl | Apr 15, 2007 02:05am | #4
      i don't think you need the tap cons... or that many shims... i'd cut it close and the put  a bead of construction glue (liquid nails) on the cut edge of the sleeper... as long as you are close the glue will fill tha gaps...  with 1 1/2" t&g  even with heavy equipment...  24oc  is prob enough... 16" might be overkill
      good luck
      p
        waynew | Apr 15, 2007 05:41am | #6
        Thanks Rez and P,Since posting the question I've actually made a start on the floor. One addition to the plan is that I've layed some of that felt tar paper over the moisture barrier.Im about a 1/3rd finished and whilst the structure seems strong enough I'm now thinking it needs some of those metal brackets to brace it to the concrete, not too many just a few here and there.I found that the concrete floor is sloping all over the place so its quite the job getting each sleeper to fit snug to the concrete and at the same time dead level on the surface. The way I do it is to cut the sleeper to the correct length, try to trim the bottom of the sleeper to the shape of the floor using the bandsaw then snap a chalk line across the sleeper and rip level using the saw, it seems to work buts its slow going. Most of the sleepers still need some shimming but shaping the bottoms seems to cut down the need for so many.Regards,Wayne
  2. rez | Apr 07, 2007 09:54pm | #2
    Greetings waynew-
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Parolee # 53804
    1. rez | Apr 14, 2007 11:08pm | #3
      Well, let's run this thru once again...
      bump
      Parolee # 53804
  3. Hudson Valley Carpenter | Apr 15, 2007 05:39am | #5
    Line levels are pretty worthless, unless the line in tied off VERY tight.  Even so, It would be much simpler and more accurate, using a builder's level to shoot the shim points.  An alternate method is to tie off you line tight, then put a common size block under each end of the string, thereby suspending it above the sleeper to be shimmed.  Then you can take a like sized block and use it as a guage, placing it under the string and on top of the sleeper, at each shim point.
      waynew | Apr 15, 2007 05:49am | #7
      Thanks for the tip, the lines are pretty tight but I'll check them again tomorrow. I'm also using a four foot level and everything seems to be lining up quite well.Thanks
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
