Levelling compound for wood flooring
Levelling compound for use with face nailed heart pine flooring?
Has anyone used a levelling compound successfully under wood flooring? I’m concerned that Henry’s or Dependable might crack when the nails are driven through it. What product(s) have you had success with under wood floors?
The floor currently has 5/8″ plywood over 1″ x 6″ boards (at a diagonal). There is a pronounced ridge over the girders. I can level the floor by applying either a layer of 1/2″ plywood everywhere except at the ridges and then applying leveling compound from the edge of the new plywood to the high point of the ridge. (Actually I’ll probably use 2 layers of 1/4″ plywood with the edges adjacent to the rdiges offset by about 8″ or so so that the max. depth of levelling compound will be 1/4″.)
Your feedback would be greatly appreciated!
Bill
ask on the forums at http://www.hardwoodinstaller.com
A cementitious floor leveller will be a problem, because it will shatter when nailed. It could be used for a floating or glue-down floor. Can you sand down the ridges? Using layers of felt paper of varying widths works well.
I would have to sand down about 1/2" in a lot of places. That would only leave 1/8" of the existing 5/8" plywood.
I guess I could put an entire new layer of 1/2" down with glue, then sand the ridges down, leaving about 1/8" of the new plywood on top of the existing.
I gues that a carpenter's glue like Elmers or Titebond would work best in the areas to be sanded. Glue it; screw it; remove screws; sand it down
Any other ideas?
Thanks for your feedback!
Bill
Check out Ardex. I think you can trowel it out up to 3/4" thick. The carpet installers I've worked beside use it all the time and they whack in their tack strips with a rock tied to a stick the next day. It has some give and doesn't "shatter".
Bill:
If you are talking about an 8" area needing fill, you can keep that area "between" the face nails (assuming the flooring is laid perpendicular to the fill). Mark it well though so you can't forget exactly where the fill is. If you end up hitting thick fill with a face nail, 9 times out of 10 the gun will drive the nail into the surface of the wood accordian style, creating a large, deep gouge, ruining the board (always the last nail on one of the best long boards in the rack, in a place where removing it requires great pains to avoid ruining several other boards already nailed tight, and where filling the gouge instead of replacing the damaged board would stick out like a sore thumb). Don't ask me how I know that.
Be interested to know what else you discover -- have run into similar problem more than once. For small dips, I just use an extra layer of paper or two, cut to the shape of the dip.
I looked into Ardex and called their support line. The manufacturer didn't recommend it for nailing through (said that it would likely spall).
What I started to do (yesterday) was to fill in with varying widths of 1/4" luan underlayment. Up against walls, I used a belt sander to feather this down to under an 1/8" thick where needed. I installed this with Titebond carpenters' glue and screws. The plywood terminates at the high point of the ridge. I will remove the screws, then sand this down. At the high point of the ridge I will sand all the way through the new layer of 1/4" plywood. One foot away, I may only sand it down 1/16" or so. Ending up with the low spots filled in with solid plywood glued to the existing plywood floor that starts out at the edges at a feather edge and that may be 1/2" or so further from the edge.
Yes, this is a lot of work, but I think that it will result in a top knotch job.
I did think about taking all the floor up (5/8" plywood and the diagonal 5/4 boards under it, but this would involve a tremendous amount of work especially adjacent to walls and the existing kitchen base cabinets (which would have to be removed and then re-installed.
Thanks for all the feedback!
Bill
#90 roofing felt works too
