Locksets installed in metal doors
| Posted in Construction Techniques on March 20, 2005 08:07am
Hey All,
I need to install a few locksets, actually deadbolts in three metal doors. these are existing doors. Is there a hole saw made for this like you would use for wood doors? Also how would I achieve a mortise for the latch and strike plate on the metal dooor and frame? I’m a little stumped. Thanks
Don
    Sphere | Mar 20, 2005 08:19pm | #1
    Bi-metal HS. cuts just fine.
    "Sell your cleverness, Purchase Bewilderment"...Rumi
    RichColumbus | Mar 20, 2005 09:01pm | #2
    Agree with the Bi-metal hole saws... they'll work just fine.
    The mortise... I use a Dremel with a cut-off wheel to cut the metal skin... then install as normal on the door.  ***Note... be sure there is a wood core on that metal door... otherwise... you may have nothing to attach to.
    On the frame... you're stuck with with a surface mount for the strike plate (unless there is something different about these door frames than most commercial door frames).  Hopefully you have at least that much clearance.
    1. DonD | Mar 21, 2005 03:04am | #5
      Rich,
      How am I to be sure there is a wooden core on the door?
      1. FastEddie1 | Mar 21, 2005 03:55am | #6
        If it's a residential metal door, it's probably a sandwich of metal skin over a wood core, and the core is readily visible on the edges.  If it's a commercial doo, chances are it's a hollow metal construction, in whiuch case the metal wraps all the way around the edges.
        RichColumbus | Mar 21, 2005 05:01am | #7
        Pop the door handle off and look inside of the hole.
  3. gordzco | Mar 20, 2005 10:08pm | #3
    Get drive-in latches, they usually fit snugly in a 1" hole. Unless of course you are using Schlage hardware which has a junky plasic cap to achieve the same effect. Schlage is quality hardware but I wouldn't recommend it in this application. For a deadbolt in a steel frame I would just drill a 1" hole and skip the plate.
    View ImageDrive- in latch, sorry couldn't find deadbolt example
    View ImageMilwaukee, Bosch, all make similar kits.
    1. DonD | Mar 21, 2005 03:03am | #4
      Thank you guys
  4. rasconc | Mar 21, 2005 07:02am | #8
    I had a niave customer whose florist shop/antique/furniture store was broked into.  She said she sure wished she could get deadboltsfor her commercial steel doors.  I asked who told you you couldn't?  Her previous contractor was her answer. Just as the others said get the bi-metal holesaw kit that is marked for steel or wood and you are there.  The big boxes have one with a cheezy guide for under $20 with both 2 1/8 and 1" holesaws.  Ones I have seen are orange instead of white or black which is usually not bi-metal.
Choosing a Paintbrush
  • The New Old Colonial
