hello all!
im rebuilding a laundry room, and need a heater that will work, and protect the pipes from freezing, when the power goes off…they have propane, and i have found out that if i use an unvented model, the unit will shut off, in small rooms, cause it has an oxygen depletion sensor…so for protection, i need to use a direct vented model…the smallest possible…so far i have only found, the EMPIRE DV-120P…AT around $500…seems nice, even has a thermostadt…
if anyone knows of any other unit, i would be appreciative…thanks steve
Greetings steve,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
