Lrg Window – Replacing Sin. Pane w/Insul
DesignBuild | Posted in Energy, Heating & Insulation on February 14, 2007 02:34am
Hello all,
I just purchased a new old home (1954) — the living room has a very large window bay, approximately 12’wide x 9’tall with hoppers at the bottom and fixed panes at top – the fixed panes are approx. 24w” x 7’h and they are single pane windows. These windows face north, and I live in the northeast, so needless to say it is pretty damn cold in that room. I’m strapped for cash as most new home owners are, and I know it would be a fortune to fully replace the window bay — so I would love to just replace the panes with insulated glass panels.
The inside frame of the window is fairly deep – 3.5″ and the pane is held in place by basically a piece of standard base molding. I was thinking I could carefully pull that out and rip it to accomodate the larger thickness of the insulated glass panel.
Does anyone out there have experience with this and have some recommendations/advice on pitfalls etc… I guess my biggest concern is removing the large old piece of glass without killing myself. I’m also concerned that the new heavier double pane will affect the window frame and cause issues opening the hoppers below.
Anyway – hopefully someone has some experiences to share.
Sean
  1. VaTom | Feb 14, 2007 05:21pm | #1
    Major weight difference with insulated lites.  You presume it won't fall off the house...  Or by "bay" do you not mean extruding?
    Good luck.
  2. tab1 | Feb 14, 2007 06:12pm | #2
    For deep framed windows I've made new frames that fit inside the existing frames. Strips of adhesive foam sealed the edges and a single layer of heat shrink plastic for the 'glass'. They worked very well. Removable if not in winter.
    I'm now experimenting with a layer of plastic on each side of the frame, for more insulation. Should be significantly better for almost no extra cost.
    For a more permanent set-up, you could make the new frames to fit insulated glass units you could special order. Caulk the edges, paint, and I'd think they'd be barely noticeable.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
