Milwaukee metalcutting blades for the RS
Disputantum | Posted in Tools for Home Building on June 30, 2007 10:33am
I had to cut some 3/8″ stainless steel bolts today.  I tried using the reciprocating saw with Milwaukee metal-cutting blades (the ones they call “the torch”).  They’d get through about two bolts, and then they were shot with the teeth almost gone.  I ran out of blades for the RS and switched to a hacksaw with an Ace Hardware blade.  It zipped through the last five bolts with the application of a little elbow grease.
Has anyone had such bad performance with the Milwaukee blades?  Or did I have a bad batch?
  1. sawtater | Jul 01, 2007 02:46am | #1
    the best blades i have found are lenox.
    outlast milwaukee 2 to 1
    maddog3 | Jul 01, 2007 05:49am | #2
    you answered your own question.
    there is nothing wrong with the Milwaukee blades
    you were just cutting too fast using the RS
    I use regular holesaws in stainless junction boxes and as long as the speed is slow and you maintain pressure the holesaws will not be damaged, of course a lube is helpful, but not necessary
    using a hacksaw was the best thing to do,
    compared to the big saw
    , wer ist jetzt der Idiot ?
    IMERC | Jul 01, 2007 07:17am | #3
    Lenox... much more gooder...
    WOW!!! What a Ride!
    1. wood4rd | Jul 01, 2007 04:17pm | #4
      Ditto on the Lennox, their the goodest.
  4. highfigh | Jul 01, 2007 04:45pm | #5
    I have found bi-metal blades on a hacking saw to be the bestest.
    1. iluvgear | Jul 02, 2007 03:08am | #6
      Lennox blades are great, certainly better than Mil or yellow blades.  I have also had very good luck with Bosch blades.
  5. FNbenthayer | Jul 02, 2007 05:58am | #7
    4" angle grinder with a thin disc is the best I've used.
    The awful thing is that beauty is mysterious as well as terrible. God and the devil are fighting there, and the battlefield is the heart of man.
    - Fyodor Dostoyevski
      dieselpig | Jul 02, 2007 02:50pm | #10
      Yup..... there's something to be said for the right tool for the job.
      That being said.... I've frequently used a single Lennox blade to cut off a whole house worth of foundation bolts (after bolting the sills of course) flush to the nuts.  I seem to have better luck with Lennox blades than any others.View Image
  6. sandalboy | Jul 02, 2007 06:46am | #8
    Like mentioned earlier you were running the blade too fast.  The heat buildup is what kills them prematurely.  3/8 isn't that big and the blades should cut lots of them.  Maybe the Lennox are better, but the Milwaukee ones are not bad.
    My favorite tool for stuff like this is a portable bandsaw.  It's quick, blades last a long time, and it doesn't throw sparks.
    My second choice is the angle grinder with the thin cut-off disk.
    My third choice would be the sawzall, running slowly.
    1. Disputantum | Jul 02, 2007 07:11am | #9
      OK, next time I'll run it slower and use Lennox blades.  Or just use the hacksaw in the first place.
A Practical Perfect Wall
  • The New Old Colonial
