Hi All,
Called a 1/2 dozen plumbers today and had one return my call. Still early yet but thought someone here could help.
Kevin
There are important considerations to keep in mind when building a slab-on-grade home with continuous insulation.
what's the need???
WOW!!! What a Ride!
Raising the house, plumbing inspector says sewer line and water line usually get replaced after heavy equipment is gone, cribbing and "I" beams. My lines run next to house, not sure it will be crushed like he says. Just the same, I would want to update it if its the old stuff that fails eventually. Also need to reconnect all the waste and water lines cut to accomodate the lift. Not that many really as it is a small house with water and sewer on the addition added 20 years ago, rest of house is 125 years old.
Your in Colorado! Thought you might be a plumber in Jersey. Also we share the same birthday.
was giving ya bump...
everybody is down in Tav for a party...
whats Tav?
the Tavern....
special handshakes and passwords to get in..
feel kinda stupid for not getting that. somehow i'm in, not sure how it happened.
so go join the party..
checked it out, seems like their covering everything, liked the discussion on who the republicans will run but still very early for that.
how soon ya need a plumber..
soon, hoping all will be done before new year. scrape and paint in the spring. i'll give you a message # for picture of the house.
got a sister who has a house in LBI, knocked down the old one and built a new one this summer. only 6 months late on completion, and the plumber's work was shockingly poor.
my guess is that you're up the creek. you may have to import a plumber.
SHG
it's amazing how everthing is different down there. i've been asking around up here, probably will "import" one as you say.
picture of house from side.http://forums.taunton.com/tp-breaktime/messages?msg=69253.9
I remember it now..
so did you opt to angle brace from the rim joist to outter porch support??
pretty much, I'll be doing it tommorrow and I'll post picture when it's done. Tore all the decking off allready.
Thought it was you who asked, here are the most recent pictures. Waiting for permit to fully demo porch joists, posts and remaining decking.
http://forums.taunton.com/tp-breaktime/messages?msg=69253.13
