need advice
buggsy | Posted in General Discussion on January 10, 2005 06:09am
have a 60year old house.The ceiling of the upstairs rooms mimic the shape of the outrside of the house.There are 2 by 8 rafters with no insulation between them.I wouldlike to install 2 inch ridgid insulation between the rafters and then a layer across the whole ceinling then drywallon top of this.Leaving an air barrier between the roof and the insulation.Also their are no soffit vents or roof vents now I willput in a ridge vent and soffit vents.Does thhis sound like the way to do it.Would appreciate any input.
  1. Piffin | Jan 10, 2005 06:35am | #1
    It is a way.
    A possibly very labor intensive way.
    Some other ways;
    - Fill space with blown cellulose and no vents but adding perfect VB
    - place FG R-19 with space aboce for ventilation and run 1" foam board then SR over furring
    - my favorite - spray urerthene foam to back side of sheathing. Expensive but definitely best and needs no vents and no installation labor from you.
    1. rez | Jan 11, 2005 06:50am | #4
      So, we're back to fiberglass batts in a cathedral roof again?
      Edited 1/10/2005 10:50 pm ET by rez
    2. onthelevel | Jan 11, 2005 07:47am | #5
      I agree with Bugsy, spray it in solid and forget the air
      1. Piffin | Jan 11, 2005 03:28pm | #6
        I don't see that bugsy said that , nor did I recommend otherwise. I just listed options
    skyecore | Jan 10, 2005 10:57am | #2
    i asked a similar question awhile ago in this thread http://forums.taunton.com/tp-breaktime/messages/?start=Start+Reading+%3E%3E
    measure once
    scribble several lines
    spend some time figuring out wich scribble
    cut the wrong line
    get mad
      skyecore | Jan 11, 2005 03:33am | #3
      oops, that link dinndt work correctly, you could just search for "2x6 rafter venting"-->
      measure once
      cut the wrong line
      get mad
