No sill plate on house on piers
dashboardchic19 | Posted in General Discussion on August 15, 2019 02:24pm
We recently added on to our two bedroom house.  We added on a master bedroom and bath. Our plan was to do a second renovation and expand the kitchen. At the end of the construction of the addition the contractors let me know that the original house is Built like a shed. They said there is no sill plate. I was told the ceiling was not built well either. They said to remove a wall the house would have to be reinforced. Now I regret adding on I didn’t know the house was so poorly built. We had to have an inspection before beginning and everything passed. Now I’m scared that my home is not safe and we spent money on adding on to a poorly built house. Is there anything I can do now to make this structure stronger. Can a sill plate be added on? The house is on piers if that makes a difference. I’m depressed about the whole situation.
    Mike_Mahan | Aug 15, 2019 05:07pm | #1
    If the house is on piers, where is the missing sill plate supposed to be?
  2. ktkcad | Aug 15, 2019 07:44pm | #2
    If the house is on piers, the beam(s) between the piers are the sill plates. If the subfloor is 2x 'car decking' then the first row of decking is the sill plate. Unscrupulous developers do nail wall studs directly into it, skipping the base plate.
    I have seen houses where interior walls do not have a base plate and they are just toenailed into the floor. This might be interpreted as no sill plate but is a totally different scenario with its own problems.
    Hire an independent Structural Engineer to inspect and explain what they find. You are going to need one to do your next project right anyway. Your contractor may be taking advantage of your nervousness to get a few extra projects out of you. Designers & Architects don't typically look as deep until the walls and ceiling are opened up.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
