Old House in Colorado.. Opinions..
WillGeorge | Posted in General Discussion on October 24, 2005 07:08am
I just got a call from my daughter-in-law…
I’m just a wood worker and knows little about construction.. SO here goes… I may ramble a bit because just talk and no pictures..
House built in 1945 or so in Colorado Springs area? Well anyway..
A old inspection report said that one wall was pushed off the foundation a bit by the ground next to the house??
I really can’t imagine land pushing against a wall BUT.. Who knows..
From my best understanding it is a wooded wall? and in the back of the house the land is lower..
SHE WANTS this place really bad.. I say stay away.. But I ask anyway..
Were houses made this way where one side is cut into the ground next to higher land and over the years the dirt just pushed the house? I have no idea what kind of foundation there is.. Did they use wooden foundations? and the inspector said wall in the report?
I understand that this area has freeze/thaw cycles that go on all year and I think just happened over a long period of time..
I know it is not alot to go on but may make some sense to one of you experts… Can it be corrected? SOme guy said all ya need is a French drain.. I’m thinking a ditch with just gravel and some pit out there to collect the water.. I really have no idea what a French drain really is..
As I see it it will go on forever or is it possible to correct and will take another 50 years to push it again?
Thanks in advance
    aimless | Oct 24, 2005 07:50pm | #1
    This bump will keep your note where professionals are more likely to see it.
    In the meantime - Colorado is known for its expansive soils, which are quite capable of caving a foundation.  My understanding is that they actually have some specialized construction techniques they use to accomodate this soil movement. Is it possible that the wall wasn't pushed but the foundation has moved from under it?
    1. Reg | Oct 25, 2005 01:37am | #2
      I'm in far northern Michigan and as a contractor and ASHI home inspector I encounter many basement walls that are bowed in (and cracked). The 8" concrete block walls are most common here, hence that is where most inward bowing is seen. Have also seen a few bowed concrete walls as well as treated lumber framed walls (which are much less common).
      A wall does not have to be backfilled with expansive soil (clay) to bow. Even granular fill will cause a wall to bow inward if the soil does not drain properly. Water exerts a lot of pressure on its own, but water permeated backfill, that freezes and expands, is nearly unstoppable. A major cause of bowing, in areas with freezing temperatures, is allowing water to lay against the foundation wall (and soak into the soil).
      I've repaired bowed block walls by excavating along the exterior and then pulling the wall back into plane by installing numerous "dead men" at the exterior and then turning the nut on long threaded rods that go from the basement interior, through the wall, to the dead man. Drain tile and granular fill are then placed. This repair is typically accomplished without jacking the home. There are many other methods.
      Problems and repairs can be avoided by correcting any reverse slope adjacent a home that allows water to pond. If there is a hill behind the home, a swale can be constructed that will direct water around the home and away - perhaps to the street. Improper grading around a home is the #1 cause of basement water infiltration. Water collecting against the foundation wall, then freezing and expanding, is the primary cause of bowed foundation walls in northern regions. Hope this helps a bit.
      Reg
    2. Scarecrow | Oct 25, 2005 01:42am | #3
      I lived in CO Spring for quite some time (20yrs)  Expansive soils are an issue but it depends what part of the city you live in.  some areas are worse than others.
      What part of town is it in?
        aimless | Oct 25, 2005 01:57am | #4
        Not me, I just bumped the thread.
        1. WillGeorge | Oct 25, 2005 03:33am | #5
          TO ALL::Thanks for the info.. I will try to get some more information..
  2. Schelling | Oct 25, 2005 05:12am | #6
    If your daughter wants this house, she needs to have her own inspection done and talk to a contractor about the costs to fix any deficiencies. She can make this part of the contingenies of a contract to purchase the house. She will, of course, have to pay something for this information but I can't imagine money better spent.
    We can tell you little from your description but someone of the site could probably tell you at a glance.
    Also, a french drain is essentially what you envision. It may lead groundwater to a dry well or to grade if there is adequate slope to the lot.
Flatten Planks for Cutting
If you need to create a straight and uniformed bevel for a scarf joint, a cupped board can be problematic.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
