My mud boots have been converted to mold boots – thanks to the wonderful humidity last summer. See attached pic. What to do?
There's a constant source of clean water for you to use, and all you have to do is collect it.
probably from the inside out...
WOW!!! What a Ride!
No - they are not mold inside... just outside.
No stink either.
Matt
Edited 1/15/2005 6:11 pm ET by DIRISHINME
If you hold the shoelace out across the floor, and wait very quietly, you can usually trip the little buggers when they run by. Then stomp on 'em.
Come on Matt, some of us have smell-o-vision software.
That's not bad at at all. I had a pair of redwings that were encrusted with mold. They looked like Teddy Ruxpin.
I wiped them down with a moist paper towel and their fine now.
Although as IMERC said, if you have problems from inside out that could be much worse.
Jon Blakemore
Sounds like you need a boot dryer.
Irish,
Powdered cinnammin, cinamummummaum, ya know, that stuff you put on yer taost wit sugar and butter.
Any hoo, it's a natural fungicide and it'll make your feet stink sweet.
Use as foot powder.
SamT
Thanks. I'll try the cinnamon on the outside but I'm looking for a remedy for the current situation, not a preventative. It's the leather that is so nasty. It's kind of a fine suede. The insides are not soiled. It's not from them being left wet - it's the humidity mixed with non use, as these are for extreme cold & wet weather. Maybe something to do with the fact that these are K-mart cheapy specials... Matt
Saddle soap and a fairly firm brush or a washcloth. If you have a favorite boot dressing, reapply it after the boots are dry.
Sounds like a good excuse to get on Cabela's website and get some new boots!
I use Lysol brand disinfectant spray, find your favorite scent, wet them down good with the spray and also extend the can with your hand into the shaft and spray a few good bursts toward the toe of the boot, then another spray burst into the shaft of the boot. Let them set for a few hours. Wipe and wash the outside with saddle soap and let dry some more. Finally apply your favorite boot dressing.
Whenever I store boots or leather items I will give them a spray of Lysol before storing them. Keeps them sweet until next usage.
Virginbuild
OK - that makes sense, and we have some Lysol... Thanks. First though, I'll have to see how the cinimon comes off... (earlier post). :-)
Are Matt
