outdoor wood/steel furniture/sculpture
I’m taking a welding class and have some aesthetically interesting ideas for some outdoor furniture/sculptures. My question is about the reactions between wood and steel. Does some wood react more aggressively with steel when in direct contact? Also, any suggestions for preventing rust besides a rustoleum every year? Some of this “furniture” would be for sitting. I live in MN also so the weather is not very forgiving. I’m aware this may not work out but I learn so much from you guys that I figured I’d give this a shot. Thanks in advance.
as far as rust.. you can powder coat it but that takes away from "metal as art" if you are use'n solid stock... you can oil it and let it rust... when they charge extra for this it's called "patina" any wood that will stand up untreated outdoors will be high in oils and shouldn't hurt metal...
or you could just do your "art" in stainless... ;)
painted just never has the feel or weathered
p
Hey thanks for the response. I'm brainstorming and this helps! Thanks a lot everyone.
Bright steel adjacent to woods that are high in tanic acid (e.g. oak, cedar) will show black streaks very quickly, although steel will stain most wood eventually
Thanks for your response!
i second powdercoating, if function is your thing. Your wood will most likely be in several pieces. A rustoleum-like solution will be a headache.
Or use aluminum stock if you're allowed. Did that last year for a portable computer kiosk for the city. Had an aluminum tube frame on casters fabricated, then attached plywood and polycarb panels for 4 computer stations. The whole unit went to various summer festivals for citizens to type in suggestions for city improvements. Modern design, looked and weathered well.
If you have to do steel and want a more sculptural look, i'd second natural. A way-cool design could integrate both. Use redwood/cedar to stand up to the elements, and keep your steel away so water doesn't drip to the wood.
Thanks for your post man!
Also keep in mind powder coating can be clear as well as a number of colors.
There is also galvanizing and other plating of various kinds.
Industrial paints used for everything from subway cars to airplanes are also much more durable than a normal enamel.
Thanks man.
Don't try to avoid the rust -- embrace the rust! Use Cor-Ten.
Mike Hennessy
Pittsburgh, PA
What is Cor-ten?
I made some log furniture years ago,with Titanium spare lengths from the "iron" shop next door....chair set, adjustable reclining loungers....the client's home was on the Nicklaus course in Whistler, and...... never mind the furniture and the craftsmanship," these babies have got titanium in them just like my irons!"
I'll post pic.s if I can find/load them..Cheers,Phil.
"If 'tis to be,'twil be done by me."
It's a steel that forms a tightly bonded oxidation layer on the surface when it rusts, so it just looks like brown steel instead of flaking away. It's used for exposed architectural elements (like roofing, etc.). It's also often used for metal sculpture that will be exposed the the elements.
It was invented by US Steel. Their headquarters building here in Pittsburgh is made out of the stuff. Here's a sculpture made of Corten from Wikipedia:
Mike HennessyPittsburgh, PA
Where wood meets bare steel the wood will rot as the steel rusts. I don't know what would happen with corten but I assume the same thing. Try seperating the steel from the wood with plastic washers. If you can cut and weld aluminium, think about using that instead of steel. I have never used Ipe combined with bare wood in an outdoor application. Maybe it would resist the rot from rusty steel. If you use bolts to join the wood to the steel for sure use stainless bolts. McFeely's is a good source. woodandiron
Thanks everyone for the information. I've got some great leads to follow!
Use grace Ice and water Sheild, or Vycor, as a membrane between the steel and the wood.
You can put on a clear powder coat if you like the color of the steel. I've seen welded steel that was clear coated and it looked good. The steel was different colors depending on how close it was to the weld.
