Quick question mebbe some of the paiters can help me with.
I recently sided a small ( 2 squares) bump out entrance way with cedar shakes. The shakes were factory primed. I rolled and then brushed on the first coat of finish paint. Getting between the spaces left for expansion (1/8″-1/4″) seems impossible.
Had it been a larger project, I would have considered renting a sprayer…..but its all cut up with windows, door, rail and the like. Would have spent twice as long protecting that which wasn’t to be painted.
Its a custom mixed color….so a can of spray paint is out of the question.
Aside from going around with a tiny brush to get the nooks and crannies…..do I have any options?
J. D. Reynolds
Home Improvements
Edited 10/3/2006 11:29 pm ET by JDRHI
On all the shakes I put on my house that I installed what I did to get into the cracks showing the undercourse was to use a spray can color that was close and that really was good enough however there was a section that I didn't use new shakes on that the owners before me had painted and on those sections "close" wasn't good enough so I used my cheap Wagner spray gun because it was a lot easier to clean out than my Fuji turbine spray gun. It really was a breeze!
Swoosshhhhhhhhhhhhhh~~~~~~~
Creation arises, is sustained for awhile, and then things change. That’s the dance.
I've had good success in smaller jobs (and I'm not a painter) by getting on of those compressed air cans that attach to a small bottle, which I can fill with paint/stain.
My local Sherwin Williams store has them, and I've not seen them at either HD or Benjamin Moore.
Quality repairs for your home.
AaronR Construction
Vancouver, Canada
I've had good success in smaller jobs (and I'm not a painter) by getting on of those compressed air cans that attach to a small bottle, which I can fill with paint/stain.My local Sherwin Williams store has them, and I've not seen them at either HD or Benjamin Moore.>>>>>>>>>>>>>>>>
With all due repect Aaron...I used those in the past and saw a load of those cannisters on sale at HD so I bought a half a dozen of them and tried what you're saying to get into the inside of radiator rungs I was painting but you have to thin it down so much I found that it was more of a pain then it was worth...mighta been my luck that day....I donno. The cost of one of the cheap Wagner airless was well worth it. I think I paid about fifty bucks for one.
My Fuji as I said in another post was too much of a hassle for some things.I mainly use that machine for finer work.Creation arises, is sustained for awhile, and then things change. That’s the dance.
Like Andy said, a cheap Wagner cup gun will do the job. They seem to work better if you thin the paint quite a lot, and then turn up to max strength, if they have that adjustment. You've got to spray from a bunch of different angles. spraying upwards at 30º seems especially important.
zak
"so it goes"
