I’ve got to repair some baseboard in a mall store. It is one piece base and shoe, MDF, melamine coated. Filled the gouges with Durham’s. Now, what would be the most durable way to paint it?
scuff sand it to get some bite
prime it with BIN 1-2-3
top coat it with semi-gloss enamel of choice
I use BIN primer to get me out of all kinds of scrapes but when I primed one of those euro-junk bookcases with it and painted it, any scratching takes it off - primer and all.
Maybe a good time to use the Flood product mentioned above. Sounds like just the thing for a smooth surface re-paint.
http://grungefm.com
Flood makes a product called "Easy Surface Prep".
http://www.flood.com/Flood/Products/Interior/Specialty/ESP+Specialty+Page.htm
I've used it before painting on all kinds of problem surfaces, and it is terrific. Basically, you just brush it on, then wipe it off, let it dry for 90 minutes, and then paint away.
You'll probably not find it in the home centers, but most paint stores carry it.
With melamine, I would run over the surface first with a pad sander to roughen it up a bit.
"It is what we learn after we think we know it all, that counts."
John Wooden 1910-
The "most durable" way?
epoxy paint
urethane based paint
There is a melamine paint, but it seems to be sold only in Canada
or the most durable with the easiest materials?
i would sand it aggressively, use a bonding primer like XIM and topcoat with something like ProClassic, either waterbourne or oil
I did find a urethane acrylic called "cabinetcoat". Says it can go over lightly scuffed melamine and laminate. I will try it on a scrap before I go to town with it...
use one of those special primers made for plastics.
Phill Giles<!----><!---->
The Unionville Woodwright<!----><!---->
Xim makes bonder primers that are for difficult to paint surfaces.http://www.ximbonder.com/
