Does anybody have any good suggestions for painting a wall where it meets a popcorn textured ceiling?
![](https://images.finehomebuilding.com/app/uploads/2024/07/26121735/FHB-Pod-Ep-642-Short-1-Feature-thumb-16x9.jpg)
Learn about solutions and fastening methods to prevent truss uplift issues.
Cut in by hand and don't look right at the brush line, look 'away' from your hand or ahead a bit to cut the best straight line you can. Keep the paint down the wall a bit, away from the popcorn and things will look much straighter.
Pretty much what Waters said.
Don't try to paint completely into the wall/ceiling corner. If the ceiling color comes down on the wall a bit it looks fine. But if the wall paint gets on the ceiling at all, it looks bad.
Rich Beckman
Coming to the Fest? Don't forget pencils!!!!!!!!!!!!!
Yes. If it hasn't been done, take a few minutes and save yourself the aggravation. Get a sanding block with a 45 deg wedge on one side. Now lightly sand a very shallow (but straight) line all the way around the room where the wall intersects the ceiling. I'm not talking saw cut, just enough to remove a pencil width. It cleans up the edge, gives you a straight line to cut to, and looks better. The popcorn abrades off so easily it takes almost no time at all.
Real trucks dont have sparkplugs
Great advice! I appreciate it.
I've used a sharpened screwdriver or an awl to run a line at the wall ceiling line. It works for me.
Headstrong, I'll take on anyone!
Sounds good.
