Parts to repair windows
| Posted in General Discussion on September 11, 2000 06:14am
I need some parts to repair some windows. These are wooden windows and the moveable sash rides in a plastic trough; the trough has two small steel clips near the top that snap out to catch a mechanism in the sides of the window and allows the sash to be removed from the frame. These windows were made in the 1988/1989 time frame and are supposed to be Hunt windows; however, the only markings on the entire window are on the lift-out mechanism, it says “BSL” and has some numbers.
In any case, it’s the mechanisms that are broken. They consist of an aluminum chanel (about 1/2″ x 1/2″) with a nylon clip at the top. Inside there’s a pulley arrangement with braided nylon string runing through them. One end of the sring attaches to a long coiled spring in the chanel, the other end has a clip that attaches to the window frame.
I have several mechanisms that need replacing; one has a broken spring, several have frayed/broken strings, and a couple have the nylon clip cracked or broken. It’s been useless to go to the local window supply outfits so far – if you don’t want to buy new windows, they don’t want to talk with you.
Does anyone know a reliable supplier who may have these parts ? Canadian would be super; I’ll go through the border hassals if I must.
Thanks in advance.
  1. Guest_ | Sep 11, 2000 06:05am | #1
    I have no idea if this link will help or not. I also have no experience to tell you whether the quality is good or bad.
    Blaine Window Hardware
    Rich Beckman
    1. Guest_ | Sep 11, 2000 04:36pm | #2
      *I have their catalog, but have not yet ordered the parts I need from them. (My windows still work without, so it's one those round tuit deals) I know that I thought I would a HECK of a time finding it, and the part I need is listed in several forms of size variations. My windows are the same/similar configuration, what with the channels and string and such. I have seen these channels in the catalog as well. So, they will probably have it, as I feel they have a great selection. Parts can vary immensely and still look exactly alike to nekked eye - say, 1/16" difference in any axis, flange widths, channel depths, etc... So they do reccomend mailing the broken/old part to them so they can match it up perfectly, 'cause of the slight variations on a theme. Kinda like taking a part to a hardware store to match up, mixed with the convenience? of mail order.
      1. Guest_ | Sep 11, 2000 05:20pm | #3
        *Skip Keith, thanks for your messages; the "return to" address comes up "not a valid user" when I tried to reply directly (probably some server some where down for Monday maintenence).
        1. Guest_ | Sep 11, 2000 06:02pm | #4
          *Rich's reference to Blaine is right on. The kind of window balance you mentioned is usually used on inexpensive alumnum sash and the usual mode of failure is the nylon or delrin clip breaking or the hook on the spring breaking. I only know from living in a condo years ago - Blaine parts kept the original piece-o-c*@p windows going til we could move on.Jeff
          1. Guest_ | Sep 11, 2000 06:08pm | #5
            *Chin: thanks for your message (can't reply to you either, I think something's wrong with @home today); unfortunately, R-B Windows said they will only supply parts to the own installer network.
          2. Guest_ | Sep 11, 2000 06:14pm | #6
            *Thanks Rich, (and to Jeff too), I've messaged Blaine and am awaiting a reply. I wonder why they used such cheapo hardware on what are otherwise expensive looking wooden windows ?
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
