patching concrete
wvjack | Posted in Construction Techniques on October 27, 2003 01:36am
I spent two hours this weekend with a saw taking out 3 inches of concrete over the door in the basement of our new home.  Everything came out neat except on one corner, where I hammered out a 5inch wide 2inch deep chunk of concrete.  What is a good method to patch this?
  1. csnow | Oct 27, 2003 10:03pm | #1
    I would probably use mortar.  Is it overhead?
    If so, I would:
    1) Set a few tapcons in the void to provide some extra tooth.
    2) Set a wood form across the top of the opening, and on one side as a dam(as needed).
    3) Paint the patch area with bonding agent (optional), or wet it out with water from a spray bottle.
    4) Using the driest mortar mix you can work with, pack it in tight.
    If you are going to frame the doorway anyways, the 'form' could become the top of the doorframe.
    Best of luck.
    1. wvjack | Oct 28, 2003 12:48am | #2
      Thanks,  I'll get on it this weekend.
      jack
FHB Podcast Segment: Waterproofing Below-Grade Foundation Walls
Learn about the pros and cons of waterproofing vs. damp-proofing foundation walls.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
