PC 7800 Drywall Sander
anwalt | Posted in Tools for Home Building on October 2, 2006 04:43am
The connection between the wand and the vacuum hose of my PC drywall sander will not stay connected.
I purchased a new hose end from PC.  It is as loose as the original.
Duct (or ‘duck’, your choice) is not a solution because the hose needs to rotate around this connection.
Any suggestions will be appreciated.
anwalt
    PeteDraganic | Oct 02, 2006 04:51pm | #1
    why not use the duct tape to "fatten" the OD of the fitting so that both fit snuggly?
    The difference between stupidity and genius is that genius has its limits. -Albert Einstein
    No event in American history is more misunderstood than the Vietnam War. It was misreported then, and it is misremembered now. --Richard M. Nixon, 1985
    1. anwalt | Oct 02, 2006 05:06pm | #2
      Pete,
      Thx for the thought.  I tried that with electrical tape.  The threaded coller must fit over the 'fattened' portion.  So the tolerance is close.  No room to unroll the tape with the collar in place, so the build up diameter is not forgiving.
      It lasted about 10 minutes.
      Anwalt
    2. Notchman | Oct 02, 2006 06:02pm | #3
      Why should he have to do that?
      I always hate having to jury rig "quality" tools to make them work right.
    PaulBinCT | Oct 02, 2006 07:43pm | #4
    Could you have lost a piece inside the "slip joint"? Mine's several years old with lotssss of mileage and still fits and works great.
    1. RW | Oct 02, 2006 11:46pm | #5
      I'm wondering the same thing. Theres the threaded cap, the hose end, and the ring looking washer thing. If you're missing the washer it'd never stay together. You missing that?Real trucks dont have sparkplugs
      1. anwalt | Oct 03, 2006 09:58pm | #6
        RW,
        I looked again at the parts schematic.  The washer you reference is missing.
        Yet another chapter in the book about not loaning tools.
        Thank you for the suggestion.
        The washer is on order.
        Anwalt
        1. JulianTracy | Oct 05, 2006 05:58am | #7
          You can use a rubber washer from a metal j pipe plumbing drain fitting - works great for mine and only cost about $.40.JT
Wiring for Subpanels: The Right Cables
When running cable to a subpanel for a home addition, pay attention to the size of the wire and the amperage of the breaker.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
