In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Pedestal sink anchor alternative
| Posted in General Discussion on December 2, 2002 01:30am
I just started a 1/2 bath semi-renovation upgrade, and after removing the vanity and bowl to install a nice pedestal sink my wife and I really like, I noticed that I am unable to anchor the sink as the manufacturer recommends (2X6 between the wall studs) due to the fact that the contractor installed the drain line running  vertically in the same wall space, and I can’t install the horizontal 2by.  Also, one of the holes in the sink for the anchor studs will hit dead center on the existing vertical drain pvc pipe.  Also, the existing waste line is 2″ low tee’d off the vertical drain line.  I’m in a pickle and wonder if there are suitable methods to anchor the sink.  The pedestal bears most the weight of the sink and I know the anchor is there too keep the sink from pulling away from the wall if someone leans on the front edge of the sink.  Any suggestions?
  1. schris1313 | Dec 02, 2002 02:20am | #1
    If the vent/drain line is in the way and the drain arm is 2" too low, there is no quick fix. Get a plumber to rework the lines to the correct positions.
  2. calvin | Dec 02, 2002 02:35am | #2
    I have done this when opening up the wall for blocking was not allowed.  Set up the sink and outline what of the wall it'll cover.  Note the mounting hole locations.  If you have one framing member behind there, cut out the sheetrock that'll be covered and replace with 1/2" ply (if 1/2" sheetrock).  Fasten the crap out of that ply and use it to mount to.  Hilti makes a removable 1/4 x 20 toggler that is a toggle bolt that you slide mount in a hole, it won't fall down the wall.  You then take a 1/4 x 20 mach. screw (included) and mount  the sink.  You need enough room behind the sheetrock to flip the wings.  There's another anchor that's used to mount grab bars w/o blocking that someone here might mention.  best of luck.
    __________________________________________
    http://www.quittintime.com/
    1. kwilbe | Dec 02, 2002 03:06am | #3
      Did you ever try to rip out a lav that was silicon sealed in place? Its tough stuff. Make sure the wall board has been primed first and dry then put a bead around the entire contact area. I fit a 6" length of 3/8 clear hose to the caulk tip so a can form a continuous bead on the underside. Also consider using hard chromed brass supplies and waste since the will help the unit stay tight.
Small, Problem-Solving Square
Get accurate measurements for fine finish-carpentry work with this precision furniture-maker's tool.
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
