Proper Window Sill Pan Installation
paulc127 | Posted in Construction Techniques on October 28, 2007 03:49am
My new 132″ X 18″ window came with a two-piece sill pan that, according to the mfg instructions must be installed. I’ve installed plenty of windows before but have never needed a sill pan .
What is the proper installation method for this?
Should I caulk it to the bottom of the window itself or to the fram/flashing ? I will need to shim the bottom a little to center this in the opening
Thanks,
Paul
  1. davidmeiland | Oct 28, 2007 06:19am | #1
    Is this a PVC sill pan designed to be glued together in the middle?
    The main thing I would do is get some slope to it. I use cedar bevel siding under window pans, whether they're made of sheet metal or membrane material. And, do not caulk behind the bottom flange.
    1. paulc127 | Oct 28, 2007 07:23am | #2
      Thanks for the tips. It's two piece aluminum, that typical of my mfg'er, is not actually quite long enough. I have additional material on hand though.
Drafting the 2027 IRC
  • The New Old Colonial
