I need to buy a new router and was considering the Bosch 2 hp #1613 EVS. For $35 dollars more I can pick up Bosch’s next generation model #1617EVSPK. It comes with a separate fixed base. What is the advantage, mnore accurate calibration in the fixed mode? that you can leave the fixed base on a table?
Thx, Jerry
Jerry,
Not familiar with the model in question....just wanted to highly recomend Bosch routers in general. If any of mine ever die, I`ll have to look into the model of which you speak!
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
Are you talking about the titanium Bosch that sells for roughly 220.?
That's the one: same concept as the PC 690/691 with a motor and three different bases (fixed D-handle, plunge), this kit comes with the fixed and plunge bases. I think the "K" means it comes with a case and "EVS" means 'electronic variable speed'. .
Phill Giles
The Unionville Woodwright
Unionville, Ontario
Hey Jerry,
I cannot recommend the kit highly enough. This is the only router I use now on site, accurate, comfortable, and powerful enough to cope with any thing I ask it to do.
I also bought a D handle base to go with the kit - the supplied fixed base lives under my site router table permanently and the D handle gives me more control when routing by hand.
You won't regret it.
Neil
