My home is approximately 40 years old. Before I purchased the home (15 years ago) the previous owners had the chimney (3/4 exterior) resurfaced using 2X4s, insulation, and T111 siding. Since I have not seen the exterior of the chimney I believe this was done because the bricks where coming lose. Anyway, now the siding is starting to rot and needs to be replaced. After doing some basic research I have found that insulation should not be used around the chimney as that limits airflow. Also, the orginial builders attached the studs directly to the brick. This I have found out is another no-no. Any advice on what to do with this repair would be greatly appreciated. Thanks in advance, Bill
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
This is an easy answer for me but could be a hard one foir you
tear it down and have a competentmason rebuildit.
Sorry, but there ain't ginna be any cheaper fix that is safe
