I have a new construction where 1/2 pex pipes for a hydronic radiant system are stapled down to 3/4″ tongue-and-groove, glued and screwed OSB. The OSB is supported by TJI 230 11 7/8 @ 16″ O.C. floor joists.
I’d like to put solid, 3/4″, narrow plank, oak, hardwood floors over this but hold the total height off the floor to 1.5″
So I basically want a 3/4″ substrate to cover the pex pipes and provide the subflooring for the hardwood.
What product and techniques would be advised?
I’m currently contemplating:
1. concrete with a small aggregate size, or
2. a sand and mortar mix
In either case, I thought I’d place down pine 1×2’s to act as 3/4″ sleepers to help screet the substrate to the right height. I would also use these to occaisionally nail the hardwood to, but the primary bond I’m contemplating for the hardwood is Sikabond T55 adhesive.
A related question: Should I seek to bond the substrate to the OSB, or let it slip?
Any advice on any of this would be appreciated.
Since you are glueing down the hardwood gypcrete will be the easiest process.
Have you done this and had success? I've seen a lot of opinions that steer folks away from gypcrete for various reasons.
Yes and Yes
Nothing wrong with gyp just as long as it is not allowed to get wet continually from leaky plumbing.
