Radon Mitigation Vent through sidewall
Nailbag | Posted in General Discussion on December 17, 2005 05:36am
I just got a radon sample back. 11 picocuries is enough to ruin my weekend. When I built I stubbed out a tee from my interior perimeter drain so hooking up a fan shouldn’t be too hard. My question though is whether the vent must terminate at the roof or can it go out the sidewall.
  1. IdahoDon | Dec 17, 2005 08:24am | #1
    A major advantage of roof termination is that the air will warm slightly within the house and want to rise without the assistance of a fan.  It's a well documented method.   I can't imagine a reason venting out the side wouldn't be ok as long as a fan is used.
    Cheers,
    Don
  2. JohnSr | Dec 17, 2005 01:39pm | #2
    Was the test run in the basement? Has the area been closed for some period of time? What method was used to determine the Radon level?
    Generally at 11 pCl/L caulking, sealing and ventilating will lower the reading to less than 4. Usually no need for a mitigation system.
    Radon is a heavy gas. Terminating the vent at roof level helps to disperse the gas over a larger area. "Dilution is the solution."
Outdoor Lighting
