In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Railing for deck with a metal floor.
| Posted in General Discussion on May 6, 2002 09:29am
I have a house that was built in 1905.  On the back of the house there is a porch that was added on in about the 20’s or 30’s.  It is an enclosed porch with windows all around and finshed on the inside with bead board.  My bedroom on the second floor has a door that walks out to the roof of the porch.  I was planning on just painting on some of the white roof coating over the metal.  The problem is how to put railings up around it.  Before I can move in my insurance comp. wants the railings up or the door boarded up.  I don’t want to drill or cut holes in the roof if I don’t have to.  There are gutters all along the perimeter.  Setting pressure treated wood  directly on the metal would probably cause the metal to rust.  If anyone has any suggestions they would be greatly appreciated.
  1. OneofmanyBobs | May 07, 2002 05:25am | #1
    What is the pitch on this roof?? If its low enough so
    you can walk on it, its too low for a metal roof. Also,
    if the roof was not designed as a deck, it may not be strong
    enough to walk on. There's no way to adequately attach a railing
    without penetrating the roofing. I lived for many years in a
    house with a deck on top of a porch with a flat roof. It
    always leaked and needed to get rebuilt several times because
    it would rot. Should have torn it down and done it right.
    The usual thing for a deck over a roofed area is to build
    a new deck on tapered sleepers. This way the deck is level
    and the roof is sloped. Then you attach a railing as usual
    to the deck. The deck is connected to the house with a ledger
    and simply rests on the roof. I would lay a sheet of EPDM
    rubber over the metal first as insurance. You can do it right
    or you can do it over (and over). Put a nice railing across the
    door for now and ponder spending a couple grand to do it right.
    You do not need to board it up. Building code requires a barrier,
    not a solid sheet.
  2. grantlogan | May 07, 2002 01:25pm | #2
    I suspect this is a flat seam terne roof, rather than a pre-fab roof. (Does it have raised seams or ribs or is it a series of rectangular panels flat locked, soldered together and then painted? If it is the later, it's a flat seam roof.)
    My method for this situation, is to cut 2x blocks slightly smaller than the interior of the square posts (assuming the posts are fabricated from 4 pieces of 1x material). Set the blocks on the roof where the posts will be located. Form a piece of metal (same material as the roof) to cover each block. Each metal "box" should have a flange along each side that will lay on the roof material when turned upside down over the 2x block. Clean the paint from the area under and around the flanges and solder the "box" to the roof as well as the joints in the "box". Neutralize the flux, prime and paint the metal, and install your posts over the blocks (the posts should have a piece of interior blocking that rests on the top of the metal wrapped block to keep the outside of the posts up off of the actual roof itself). Install the rail, which is hooked to the house and gravity holds the whole thing down.
    If you are using solid posts, proceed the same way, except cut the blocks the same size as the posts and then install some sort of base molding around the bottom of the posts so it overlaps the wrapped blocks.
    If the posts are round, configure the bases to fit over the wrapped blocks.
    Now, having told you how to do this, I have to admit I have never done a retrofit like this. I have only used this method when replacing the whole roof and I only use copper anymore. Evaluate your roof before proceeding. How much life has it got left in it? Maybe it's worth replacing now.
    Plan B would be to pop rivet the "boxes" down to the existing roof and then coat with Geocel 2310 or one of the latex roof coatings rather than removing the paint and soldering. This violates the "no penetration" concept and won't be as long lasting.
    Good Luck.
    gl
    I've told you a billion times not to exaggerate.
    Edited 5/7/2002 6:28:17 AM ET by grantlogan
Building a Zero-Energy Home for Less
An Oregon design-build firm makes high performance more affordable.
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
  • Coastal Home That Mimics Nature
  • A Sturdy Rail for Outdoor Stairs
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
