Removing a lally column
MRmike | Posted in General Discussion on September 25, 2005 12:24pm
I’ve got a single story house with a basement.  The main floor is supported down the center by a 3×7 inch steel I-beam which sits atop 3″ steel columns on 8 foot centers. I’d like to remove one of the columns to make room for a pool table and I’d prefer not to have the floor cave in.
I’m thinking of sistering a second 16 foot I beam between the remaining columns or perhaps just reinforcing the vertical web of the existing beam by welding a 1/4″ x 6″ plate along that span.
Is this do-able or should I just buy a smaller pool table?
  1. GregDi | Sep 25, 2005 01:08am | #1
    You will need to a pull a permit for that work and you will no doubt need to have an engineer design and/or seal the beam.
    To do guess at what you think might work would be idiotic at best in this instance.
    Spend the bucks and be safe.
Landscape Lighting Essentials
From planning a safe and exciting outdoor lighting strategy to limiting light pollution to choosing fixtures, we've got you covered.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
