In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Removing Old Tub & Tile Caulk
JLBatey | Posted in General Discussion on December 1, 2002 11:27am
I have tub & tile caulk that was applied everywhere in a rather haphazard fashion.  If any caulk made it to the actual crack, it appears to just be luck on the part of the applicator.   The tub is cast iron and the walls are ceramic tile.  Is there a better way to remove this caulk than a single edge razor blade?  Maybe, some type of chemical cleaner?
Any suggestions would be appreciated.
  1. RW | Dec 02, 2002 02:05am | #1
    It should actually come off fairly easily if you can get behind it with a putty knife. I usually use a painters 6 in 1 tool and the pointed end. I may not lean to that here with the risk of gouging something up though. A cheap, stiff plastic 1 inch putty knife could do the trick, and you could even lick it across a belt sander to make more of a chisel edge on it. The razor tends to make lots of little pieces, if you can get a run started, you could be forutnate enough to just pull the majority of it off if you move slowly. Not aware of any chemicals to eat silicone. Acetone might, but that could cause other issues on the tile glazing. Not sure on that one either.
  2. chiefclancy | Dec 02, 2002 07:25am | #2
    There was talk some time ago in a thread about Dow Corning Cleaner and Surface Prep Solvent, and 3M Caulk Remover as chemicals that would soften up silicone. Haven't tried either myself. What has worked for me is to get as much of it up by using a razor and then using goo gone for the remaining traces. Had to scrub quite a bit, so the next time I'm going to try one of the caulk removers. Anyone had any luck with them?
Decompartmentalizing a 1940s San Francisco Home
This modernized remodel in the Bay Area is characterized by open spaces and an abundance of natural light.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
