We are installing an 30 foot long wood plank bartop (supplied by others) which is coated in one of the two-part epoxy bartop clearcoats, presumably “Enviro-tex Lite”. There is s stress-crack in the finish, about 4 inches long, right in a very visible spot. Is there a way to repair this ? Anybody with any experience in repairing this material, please help. Thanks.
We are installing an 30 foot long wood plank bartop (supplied by others) which is coated in one of the two-part epoxy bartop clearcoats, presumably "Enviro-tex Lite". There is s stress-crack in the finish, about 4 inches long, right in a very visible spot. Is there a way to repair this ? Anybody with any experience in repairing this material, please help. Thanks.
Is this a coating that can be sanded and polished ?
If so, then the easiest way to fix it would probably be to make the crack into a 'v' groove all along it's length. Clean all the sanding residue out, and pour some more in to fill it up. The new stuff should actually eat into the sanded surface a bit, and make it dissappear. Then, if you can't pour it just right, sand and polish the surface when cured.
I've done this. I didn't expect it to make the bottom of the 'v' groove dissappear the way it did. I expected to just have to explain the appearance for the rest of my life. LOL I was very pleasantly surprized when I looked at it the next day, and discovered a bit of sanding and polishing would make it totaly invisible.
