I need to replace the delaminated formica backwash of a kitchen countertop. I haven’t worked with formica before. Can anyone suggest some things I need to think about before attempting this project?
I need to replace the delaminated formica backwash of a kitchen countertop. I haven't worked with formica before. Can anyone suggest some things I need to think about before attempting this project?
Tom;
I would suggest these as the mai things to think about:
Can you get the old backsplash off without too much damage to the counter top and wall? If so, It would be a lot easier to make the repair without doing the work in place. Just toss the old one and make a new one.
If you've never worked with formica before, a short run of backsplash shouldn't be too tough. And you won't be spoiling a whole sheet if the first try messes up.
I never had much luck spreading the contact cement with a roller. I've used a very finely notched trowel with good results.
Think about whether to put the narrow piece on the top edge first, or the wider piece on the face first. It makes a difference as to how visible the dark cut edge will show. Ditto if there are going to be little cap pieces on exposed ends.
Also think about how you will attach the new backsplash. Probably some kind of mastic or construction adhesive. Just check first for bulges or hollows in the wall, because those can make it tough to get the backsplash to fit tightly.
Good luck
Jay
