A friend of mine has a “lake house” that was orginally built in the 50’s. It has a walkout basement that has what appears to be an orginal bath “area” (no walls around it) in the basement. Stool, basin, and shower.
The shower is a campground style. That is drain in the concrete slab and concrete block walls. The drains are all CI. There is another basement floor drain a few feet away.
The desire is to frame up walls, install a vanity and replace the shower with a FG unit.
The question is is there any change of getting a transistion fitting that will go from the shower unit drain to the floor drain without cutting up the concrete and redoing the CI piping.
You mean run the line across the floor and then a fittinf that replaces the floor drain strainer cap?
Dave
No, the shower would stay in the same place. Directly over the drain for the existing shower.
