roof vent question
user-97129 | Posted in General Discussion on December 14, 2006 10:54am
hip roof – cathedral ceiling – stick built – south Florida – 100% a/c. – tile roofing
down at the lumber yard and was talking to the estimators about how people were venting the above mentioned roofs.
seems there were 2 basic ways:
1/ soffit vent going to the corrugated material on the underside of the sheathing above the insulation. underlayment your choice.
2/ then they mentioned some are going with a totally sealed bay. soffit vent to sealed  blocking to insulated bay. ice and water shield as underlayment
does anyone know exactly what the performance difference between the 2 would be.
  1. Piffin | Dec 15, 2006 12:54am | #1
    Slightly more insulation means could be a bit cheaper to cool or heat normally but since you would primarily be cooling, I think the vent would help
    No vents makes it a hot roof and in S FL the shingles might be aged out a year or so earlier than a vented roof
      Gene_Davis | Dec 15, 2006 01:05am | #2
      Hipped, huh?  If it's a pointy-top, or one with relatively short ridgelines, where's all that hot moist air going to escape?  Waitaminute.
      Woops!  Hemmed in by my regional practices, I'm thinking ridge vent.
      I recall on my last driving tour through Dixie, seeing a whole lotta those can-vent thingies, dotted all over roofs, up near the tops.  Really standing out when you're on a freeway, and seeing the rears of subdivision homes.
      Like this.
      1. Piffin | Dec 15, 2006 01:57am | #3
        I missed the hip style - focused on cathedral. To be honest, I don't think I've ever seen a hipped cathedral roof and cieling. That must be some unique engineering! Since it would be hard to vent, I might be inclined to make it a hot roof then - with urethene foam
    2. Hazlett | Dec 15, 2006 01:44pm | #4
       the O.P. says tile roof---so probably doesn't need to worry about cooking the shingles---------and as we both suspect--that may be a marginal issue anyway.
       however--if shingles WERE going to be used in this application, i would contact the shingle manufacturer BEFORE the house was built if at all possible.
       At one time I prepared a roof  proposal for an existing house with similar issues--and ELK was willing to warranty the roof materials if certain conditions were met. in the O.P. situation--it would be nice to know  what those conditions  are, BEFORE installation. LOL
       Best wishes, Stephen
  2. user-97129 | Dec 15, 2006 04:01pm | #5
    actually i did a little more research and came upon some studies done by the florida solar eneregy board. seems the best way is spray insulation. this causes a sealed cell and no moisture intrusion. seems venting allows in moisture and this is not a good thing. seems the color of the tile/shingles/etc. is the basic variable for roof temp. black is bad...white is good
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
