Router Bit Failure
JD | Posted in Construction Techniques on December 1, 2007 06:04am
I am using a bearing guided router bit to remove the sheathing from window and door openings.  The bearing falls off the end of the bit while routing.  I have gone through 3 bits so far in the course of 18 windows and doors.  I am at a bit (no pun intended) of a loss as to why.  These are brand new Bosch 1/2″ x 1″ with 1/2″ shank.  Any ideas?
    DDay | Dec 01, 2007 06:18am | #1
    If they are all the same, bosch, try another brand. I stay with whiteside and freud for bits, cmt have a good rep but I have not used them. If the screw is getting loose, lock tite might work to keep it from vibrating out.
  2. Piffin | Dec 01, 2007 06:27am | #2
    My imagination has the bearings overheating so it stops spinning freely and threads out
    IMERC | Dec 01, 2007 06:31am | #3
    the bit is over heating...
    go with CMT for a much better bit...
    WOW!!! What a Ride!
    1. Sasquatch | Dec 01, 2007 07:31am | #5
      Very interesting, Mr. Bosch!
        IMERC | Dec 01, 2007 07:38am | #6
        thank you....
        a down spiral panel bit would be a good choice too...
        IMERC | Dec 01, 2007 08:01am | #10
        wonder how I knew...
    2. restorationday | Dec 01, 2007 09:21am | #11
      this is slightly off topic... sorryI stopped by Sears the other day for a 1/2" roundover bit (2 blocks from jobsite) and there wasn't one in the lockup case so the salesman said to wait and he would look on the stock truck that had just been brought out from the back cause he knew that they had been on order. I follow him and he grabs a box with BOSCH on the side and pulls out a Craftsman router bit. I asked him if BOSCH made Craftsman router bits to which he responds "yep, same thing and sometimes they screw up at the factory and send us a box with Bosch branded bits mixed in"
      who-a-thought
      -day
        IMERC | Dec 01, 2007 10:28am | #12
        the bulk of the Bosch bits ya get here in the US are made in the Carolinas and then Europe then China...
        read the label...
    IMERC | Dec 01, 2007 06:33am | #4
    BTW...
    use a spiral piolet bit for this application...
    WOW!!! What a Ride!
    IMERC | Dec 01, 2007 07:49am | #7
    cmt panel bit link
    go here for a look see...
    WOW!!! What a Ride!
    popawheelie | Dec 01, 2007 07:57am | #8
    This is just an impresion but I think some of the Bosch product isn't as top shelf as they would like you to think. They are having parts made all over too. Just like most companies. Maybe you should try some others.
    I just ordered some blades from the Bosch factory outlet and they really messed up the order. The service wasn't that great either. They mixed up their own numbers and sent the wrong parts. Then they said they don't make them any more. I ended up buying from somewhere else for less.
  7. reinvent | Dec 01, 2007 07:58am | #9
    Either the CMT or the Amana bits will work. They don't have a ball bearing guide. It is a solid steel guide so it is bomb proof. Yes it will burn the 2X framing a little but so what.
    http://www.amanatool.com/bits-fv/45506.html
  8. User avater
    BossHog | Dec 01, 2007 10:33am | #13
    The bits we use have no bearing on them - Just a solid round thingy. It burns the wood alittle, but doesn't really matter.
    We ain't building a piano.
    Suppose you were an idiot. And suppose you were a member of Congress. But I repeat myself. [Mark Twain]
    1. reinvent | Dec 01, 2007 05:38pm | #14
      Will they work on a violin?
  9. User avater
    Dreamcatcher | Dec 01, 2007 06:08pm | #15
    JD,
    I see some have already posted the answer to your problem and I agree with those who say to get a panel pilot bit. It is what they are made for anyway. The point allows you to punge the bit in, crating it's own pilot hole. You don't need to order from a catalog or website, just run down to the depot (http://tinyurl.com/2zc5mq). I recommend the 1/4" shank, 1/4" cutter. It cuts faster and vibrates less than with the 1/2" cutter. Either way, if you try to go too fast you will fry the bit and break it.
    As far as the bearing bit goes, you are using too large of a bit. Just as with the panel pilot bit, the larger cutter creates more vibration and there is nothing you can do, the bearing will work it's way loose. Worse yet you could melt the bearing if trying to cut through thick materials or hard materials. These bits are made more to shave than to cut.
    gk
  10. rlrefalo | Dec 02, 2007 01:03am | #16
       router to cut openings? I think put the effort into something that will make a difference. Chainsaw or sawzall for cutting sheathing.
Why the FHB Summit Is an Industry Event You Don't Want to Miss
The Fine Homebuilding Summit is finally back after a six-year hiatus — and it's going to be better than ever.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
