PC D handle model 690. Router would go on and off while using it. Finally stopped altogether. Replaced the brushes and worked for a couple of minutes. Stopped working agian. Tested switches and cord both supply power to the router. Any ideas what could be wrong? Thanks.
We tried out a range of rotary and random-orbit sanders to compare their dust collection, quality of finish, and user fatigue after hours of sanding.
Dust in the switch, or a broken wire in the cord. The cord was probably in the right position when you tested it. Buy a new cord, they are cheap.
Edited 3/13/2008 6:23 pm ET by FastEddie
Cord was the problem. Thanks to you and the others who responded.
What he said.
I have the same router. There's something wrong in my D handle plug... works, won't work, works, won't work...
I've one of those ball bungee things wrapped around the whole mess that will keep it working until I have to unplug it to unscrew the body to change bits.
New D handle costs $65... I love the router, but have been too scattered to really fix it for 10 years<G>
Lemme know what you do... LOL
Winterlude by the telephone wire,
Winterlude, it's makin' me lazy,
Come on, sit by the logs in the fire.
The moonlight reflects from the window
Where the snowflakes, they cover the sand.
Come out tonight, ev'rything will be tight,
Winterlude, this dude thinks you're grand.
My PC lam trim router was doing that...I just blew out the switch using the air gun attached to my compressor...works fine now.
