what the word on spray on insulations?
thinking of using either icyene or polyurethane. Is one better or safer than the other? any off gases?
thanks
![](https://images.finehomebuilding.com/app/uploads/2024/05/21142347/01232462-subfloor-sheathing-feature-thumb-16x9.jpg)
For a stable, flat, and squeak-free floor, you'll find that most new products are OSB.
Icynene smells nasty durring instulation but after a day it probably is the lowest out gassing foam.
PUR has a higher R value by about 50-60%
Earl: Spray on polyurethane foam has an aged R=6.2-6.9 depending on the manufacturer.There are no known health risks associated with the "out gassing.A good source for more info. is the polyurethane Assn. @ 1 800 523-6154.Icene has a lower R factor but also less expensive so I guess you get what you pay for!
One of the two formulations of Icynene can go into enclosed wall cavities Which I don't think you can do with PUR. R value about 4 per inch. There web site is http://www.icynene.on.ca
thanks
