I have squeaky floors with carpet over, what are some cures. I have read of a kit with break off screws, bit and depth gage. Can’t find it anywhere.
The longer length of these 3-in. stair gauges makes it easier to ensure an accurate layout when working with waned lumber.
HD sells them .. or if you have access from below you can also try hidden nailing deck angles, screw the side to the joist then up into the floor, predrill the subfloor so that the screw pulls the hard wood tight
Thanks Wayne, I think all I have is sub with carpet, be hard to go under as its insulated. Who is HD?
home depot
Thanks again, I should have figured that out.
