Staircase layout
Attila | Posted in Construction Techniques on September 3, 2005 09:23am
Any advice on laying out and building a winding staircase. It’s not new construction…Adding access to an attic space in a raised range.
I’ve layed out and built a bunch of stairs before, but in discussing this option with the homeowner it occured to me that I’ve never framed a winder before. I have an idea as to how I’m going to approch it, just looking for some input form someone whose actully built one. Thanks.
  1. MisterT | Sep 04, 2005 02:24am | #1
    Check with the local code officer 90% of what you need to know will be in the codes.
    the rest you should be able to figger out.
    Mr. T.  MOTOL
    "I think natural selection must have greatly rewarded the ability to reassure oneself in a crisis with complete bull$hit."
    I'm Swiss!
  2. Piffin | Sep 04, 2005 02:46am | #2
    Lay it out on the subfloor and build up from there. that way, you can make your mistakes witha pencil
    Matt | Sep 05, 2005 03:41pm | #3
    This http://www.arcways.com/IRC2003.pdf has some info on laying out winders.
    As far as attic access, are the floor joists in the attic up to the task?  Even if you are not gonna pass any inspections you still probably want at least 2x8s.   2x6s would definately be border line depending on the spans.
Choosing a Paintbrush
  • The New Old Colonial
