I need one tapered stairhanger bolt for joining two sections of a handrail about 4″/4 1/2″ inches long with 3/8″ dia threads tapering to the solid nonthreaded 7/16″ dia section rod in the middle.
Each end is threaded for a nut. Can’t find anything on the web.
I know I have one somewhere as I recall seeing it sometime in the wayback history but finding something like that now when you need it is impossible.
All thread in 7/16ths isn’t going to happen and one old hole is that dia. 3/8ths is going to have to work if I can’t locate the actual part.
I thought maybe, perhaps, remote possibility, someone may have a spare they would be willing to sell.
Thanks.
be hoping to roll a seven
‘Nemo me impune lacesset’
Buy some 3/8" threaded rod and have the middle turned down by a machinist?
Let's not confuse the issue with facts!
Ya, got some 3/8 thread rod today.
The middle of the bolt would need to be 7/16 with the threaded 3/8s tapering to each end. Hole in one end of the original rail is a tight 7/16ths.
Was hoping to simplfy matters but I can make it work.
be good enough for the kind of girls I go out with
'Nemo me impune lacesset'No one will provoke me with impunity
I got one or two..gimme an addy its yours.
Edit: never mind
Damm, I miss that stuff
Edited 4/27/2006 8:39 pm ET by Sphere
Thanks.
73019.1
be I need to get organized
Edited 4/27/2006 8:50 pm ET by razzman
waiting for reload thread wise I saw that...thanks. I don't have the gucamoles right now, buying my siding...mebbe CUSEEYOU wants to snag it up...I just had two short weeks and the siding is a priority.
I have that goofy wrench ya need too, or don't PRY the star, tap it with a punch.
It's alright, I ain't building a work of art.
Old curved staircase I took out of an old victorian many years ago and finally getting to the point where I could put it up.
I ended up removing the first step and the top four from it as the vicky had high ceilings and I've a storey and a half. All in pieces but I did have a numbering system back then, kind of. bwaa! be puzzled at what you did years later
Had to add a 10 inch piece of rail to the top of the banister before she curled 90 to make the rail for a balcony. Rail piece profile's not a perfect match as it was cut from the original top rail but good enough.
Using everything I'd saved from back then with no balusters left and like a footlong long piece of rail remaining.
Maybe the missing newel post ball will come out of that.
be good enough for the kind of girls cu invented
Yeah but, ain't it grand? I love that shid. BTW, use roman numerals, carving an 8 is a PITA with a chisel.
Chisel? Don't need no friggin' chisel.
be a black magicmarker and be highclass
razz can you knot increase the size of the hole to accommodate threaded rod??
or a larger dowel??
how about a smaller dowel??
3/8 allthread??
toe nails and putty!!!
Mr. T.
"My sincere view is that the commitment of our forces to this fight was done with a casualness and swagger that are the special province of those who have never had to execute these missions - or bury the results." - Retired Marine Lt. Gen. Gregory Newbold.
Ya, just wanting to match the pre-exsisting and have it accessible later is all.
be is that toejam on that toenail?
Can't believe I went ahead and used the threaded rod only to find the bolt the next day.
Here's a pic of what I was talking about.
be no I ain't swapping it out once a deed is done.
Looks like FUN! ;)
is there a reason it has to be fat in the middle(like us) ???
It don't show so as long as it works, who cares???
Definitely an antique tho, I aint never seed one afor...
Mr. T.
Besides beer and donuts I'd be guessing.
7/16 fitting tight in a 7/16 hole in the rails. Maybe the taper to 3/8s dia was for ease of getting that star nut started on the stairbolt as a small rectangular opening is chiseled into the underside of the rail a couple inches out from the intersection then later filled with a wooden plug.
The hole and bolt run into this providing the access point to slip the nut on to the bolt. Close quarters.
Got to wondering if the stairbuilders had a special wrench tool for those starnuts. Prying those tight with a screwdriver makes for a good hack job on the sides of the square opening.
be I never said I was a pro
Edited 4/27/2006 6:03 pm ET by razzman
>>"Got to wondering if the stairbuilders had a special wrench tool for those starnuts.
I would swear I have seen such a tool. Looks like sort of a crescent with a handle on one end and a hook (that engages the bolt slots) on the other.
Maybe on ebay someone would have that particular tool? Maybe just grind one up out of a piece of steel?
"Let's get crack-a-lackin" --- Adam Carolla
Ya, but don't need one now as I did the last hurrah on putting together the rails.
be I hope
