When I was in Minnesota I used a proprietary stucco patching mix that would bond to paint-primed plywood without first applying metal lathe. Called Stucco-It; my empty bucket says the company was Applied Texture of Hamel, MN. I can’t locate this company on the Net. Anyone know where I can get this or a similar product? Or do you masons know of a bonding agent I can add to ordinary cement for this use? This job is soffit repair. Many thanks.
When I was in Minnesota I used a proprietary stucco patching mix that would bond to paint-primed plywood without first applying metal lathe. Called Stucco-It; my empty bucket says the company was Applied Texture of Hamel, MN. I can't locate this company on the Net. Anyone know where I can get this or a similar product? Or do you masons know of a bonding agent I can add to ordinary cement for this use? This job is soffit repair. Many thanks.
